Wavering gravity...
Started by iacob alex, November 16, 2010, 05:25:45 PM
iacob alex
.....with a lot of pendulums , at : https://youtube.com/watch?v=w6U-05zFKuo
     With the same "cards"/pendulums ,we can play an old "game"(Newton's cradle...) or a multitude of new "games" (including yours...) and...why not? ...a self powered gravity device ?
     Al_ex
Turbo
Turbo
people usually try to maximize the magnetic forces involved in their designs.
it is a result of the faulty assumption that a magnetic field somehow represents energy.
just because a moving magnetic field can induce current flow, it still is the kinetic movement that is converted to another form of energy.
the opposite is also true current flow can be converted into kinetic energy by moving magnetic fields.
no where in these two examples is the magnetic field responsible, or the source of the energy.
the endless trying to get energy from a magnetic field has to stop for it is an journey without end.
the hypothesis was that gravity pulls on all matter, even on a tiny electron.
but the force of gravity is so weak when compared to the forces that bind electrons and keep them in place around atoms.
this is as far as we go, we assume electrons are circulating atoms, and we assume they have mass.
we also assume that the forces holding them in place are stronger then the force of gravity.
the hypothesis continued to claim that if it was not for these binding forces, the electrons would feel the force of gravity and start to accelerate in a definite direction, just like any other object does when it is allowed to fall under the influence of gravity.
most circuits people deal with in this era, are of the single directional kind.
this means current is always flowing in one direction, or it is flowing in the other direction.
never it will be flowing in one direction and in the other direction, at the same time.
yet this bi directional movement hold certain key's that are needed to make progress in the field of a,
GPG (gravitational powered generator).
simply because it is impossible to use the ancient approach of single directional fields to set up the needed field pattern.
the reason for this is that the single directional field pattern is always additive.
it can not be used to null out the forces that bind the electrons, because it can only be used to add density to the field.
where a bi or even but not necessary, a multi directional field can be used to effectively cancel out or null out the forces at play, creating a field pattern that frees the electrons from their hosts, by cancelling out the binding forces that keep them in place,
allowing the gravitational pull to finally set in motion and accelerate these charge carriers in a definite direction.
it should hold common sense to the designers of such a system, that the spacial orientation of the mechanism is of utmost importance, as well as graverodynamic design.
iacob alex
.....playing unbalance of two pontoons , due to incoming sea-shore waves , at :
     https://m.youtube.com/watch?v=-dZh7gVTKmQ
     It can be a suggestion to represent gravity fall as incoming "waves"...in a simple mechanical variable/oscillatory leverage...
     Al_ex
iacob alex
.....as an artistic expression , at :
     www.fredjulsingfansite.nl/wp-content/uploads/Kijk1.jpg
     Art is n effort to improve the understanding of the world around us...
     Al_ex
