New permanent magnet motor on youtube from Roobert33
Started by hartiberlin, November 17, 2010, 05:47:43 AM
Pirate88179
Jesus:
I do not know if that will work or not but it sure is a new approach to the sticky spot problem.  By working 2 against 1 it might have a chance.  Again, great thinking on your part.
Low-Q
If you got one V gate, with its sticky spot, - you know the V-gate we all know doesn't work, and take this V-gate and connect together with two more V-gates that doesn't work either. Let us now connect them together with a common shaft, and align them 120 degrees apart. Is it any reason why they now suddenly should work?
I cannot see the logic in this...
You will never avoid the sticky spot. You even it out, but you also add more and more sticky spots as the number of V-gates increase, doesn't you? Each sticky spot must account for itself. 100 V-gates = 100 sticky spots. 100 / 100 = 1, which means each sticky spot must account for its own sticky spot.
Vidar
Qwert
Quote from: Low-Q on November 24, 2010, 01:14:32 PM
Consider: sticky spot is associated with attracted configuration. In fact, there is no sticky spot when magnets repel; this kind of configuration is easier to manage, though attracted one is more powerful.
billmehess
Vidar
100% correct
nievesoliveras
For the negative thinkers.
I stated very clearly on the schematic that may be yours work better.
Just dont sit there and criticize my efforts. Present your solution to it.
Jesus
