Splitting the electron stream
Started by gravityblock, November 30, 2010, 12:08:47 AM
XS-NRG
here is my plan on how to replicate the slorbo effect.
Get some rusty nails and dip them in vinnager five times.
They need to be of the fe56 type.
Blow some hot air over them to accellerate drying process.
Carefully drill some holes in some ostrich eggs.
Place the vinnager dipped nails into the eggs and attach solid copper leads to them.
Now lower the eggs into a radiant energy reservoir.
At this point you should see the eggs emit a small amount of green light.
Connect the leads to any load or at this point it's a good idea to switch off the main switch in your home and connect the leads directly to your house wiring.
You can test to see if all went well by switching on the livingroom lamp.
If it doesn't work try the bathroom lamp.
Still no luck ? repeat steps one to five.
quarktoo
Quote from: XS-NRG on December 09, 2010, 03:57:25 PM
XS-NRG,
While your suggestion is clearly based in sound quantum scientific theory, and the proof of that is course the "green glow", I have a much better suggestion which I am fond of using that does not hurt big bird's babies.
What GB should do, is take two copper pipes and attach them to AC power via a really big orange extension cord. THE CORD HAS TO BE ORANGE FOR SATETY REASONS!!! Next, have Dr. Lewin pound one of then 4 inches into his forehead and the other pipe up his ass.
It would not be overunity per se, but it would be "over" and there would once again be "unity" in this forum." It also fixes crazy, stupid and removes that stale smell of loser from mommies basement.
quarktoo
Quote from: gravityblock on December 09, 2010, 03:56:21 PM
Your only focusing on one type of bifilar coil.  Below is another quote from Wiki.
As you can see in the above quote, a certain type of bifilar coil uses two wire coils wound in parallel and electrically isolated from each other, instead of the single wire bifilar coil you are referencing.  With my idea, the two wire coils wound in parallel will be energized in opposite directions at the beginning of the pulse with 0 net inductance.  Then one of the coils will be disconnected shortly after so the current is flowing at it's maximum value allowed by the resistance almost instantaneously with a net magnetic field and a net inductance.  This allows for no BEMF has the dual magnets depart from TDC because the current has no rate of change when it's already at it's maximum value allowed by the resistance.
You can be a prick and try to play with the words and definitions all you want, but it's not going to change the idea in which I'm trying to convey.
GB
That is used to suppress relay coil transients which can go over 1000 volts in mission critical systems like an auto pilot. Usually you just use a diode across the coil. The other coil is just shorted out - sort of like your brain only the relay is capable of doing something useful.
I gave you the plan to build a free energy device dumb ass. I told you how that stupid orbo works dumb ass. You are not here to learn how to produce a free energy device, you are here to mentally masturbate. Unfortunately, you have some dodgy X chromosome credentials and all males with down syndrome are sterile. Do you have a really big forehead? Could you get a big person to measure your forehead for us and get back with that info?
I am not trying to be insulting, I just want to make sure that I am not being catty with a fucking retard since that would be rude.
gravityblock
Quote from: quarktoo on December 09, 2010, 03:36:02 PM
Dude... Without voltage there is no current flow and and without current flow, there can be no resistance. Sorry dumb ass, you are still a below average pretender and no amount of more stupid is going to change that.
Without current flow there can be no resistance?  LOL.  Without current flow, there can be an infinite resistance, such as when the circuit is open.  A lower resistance, means a greater amount of current can flow.  A higher resistance, means a lower amount of current can flow.
Dude.. If the coils are not shorted, it is not a PMH... Are you high?
I never said that.  You taking what I said out of context again.
The field that is "permanent" is as perpetual as a permanent magnet. Now you are playing semantics but are too stupid to look up the definition before playing the game. Here, since you are not bright enough to even spell both the words perpetual or permanent  correctly, I'll feed you the definitions on a silver platter:
per·ma·nent
1. existing perpetually; everlasting, esp. without significant change.
per·pet·u·al
1. continuing or enduring forever; everlasting.
You conveniently left out motion.  Something that is static and permenant doesn't mean it's in continuing motion.  You can have a permanent electric field that is static, such as an electret, without the permanent electric field being in perpetual or continual motion.  Play with the words all you want, but it doesn't change anything.
GB
FatBird
