Splitting the electron stream
Started by gravityblock, November 30, 2010, 12:08:47 AM
ATOM1
All electrical instrumentation is affected by stray voltage scalar waves and so many interaction with everything known and unknown .... Conformation  only  indirect measurements from non electrical connections so try some kinetic final testing and see if will match the result ??? I very much doubt it ! When an energy is producing an OU result from electricity it will always affect the harmonic boundaries of the mass .. Try and take into account 5ths in the harmonic they set oscillations that trick the instruments into making the wrong results...
You can never except the results from instruments not designed to isolate such effects that you are looking for ! Sorry but its all quantum mechanics reactive circuits that contradict ohms law not me .............
Without a formula to start with than you are left with a map of results that can never be referenced in such a way to confirm you have achieved the base formula. Even a set of capacitors will show extra voltage but the overall pressure of the system is equal to what charge you started with if you know what you are doing ect .................................
You have to lift something or turn a heavy wheel as an indirect measurement ! But without a formula for the energy you are looking for than how do you know what you have found ?? If you drill for oil and hit gas have you found oil ?
Isolate the natural combined harmonic with the OS work out the number of particles in its wave and isolate them by reactance ! Make them hit a silver plate work out the electrons being shifted than you will know the real mass in the harmonic wave form ........................ It has to be particle physics not electronics or stupid microprocessors !
I can tel you are hoping to find that the atoms are going to power up the function hahahah Only I can do that hahahah you need my unified field oscillator for that as there is no other way ..................................................................
Leave those atoms alone its not legal to mess with atomic energy ok !!!! What is you get a runaway train effect where all mass turns into light ??? pendulums my friend ! Get lots of them set them up swinging  and watch them all end up in unity .... Work out the numbers and you find some free energy but why ????
Stick to this and look at the electrons that are free like independent pendulums ! Do I really have to give the game away hahahah  Leave the atoms alone in all your equations don't even bother with them .. Group up the electrons with magnets and hit them like pendulums releasing real force to push something .......
OR CHOSE ANOTHER FORMULA ! Hit and miss oh look the volts are goingg up we are nearly there hahah sorry but that is not how to do it ! Either way leave the ATOMS ALONE ...
ATOM1
