808 G6 OSIRIS ENERGY TECHNOLOGY
Started by osiris, December 03, 2010, 09:33:16 AM
osiris
Quote from: FatBird on December 10, 2010, 02:48:16 PM
Does anybody have a schematic?
@ fatbird ..  i will hand draw you 1 just for you   :)  ok
its kinda owed to you  ;)
thank you jesus !   glad your still round
basiclly  there 6 wires for the g6's  all the SAME LENGTH ...   then there is a trigger wire .. 1/3 length and a pulse wire full length...  multi wound ...
the g6 wires are wound first in an interleaved  ac configuration ...
high voltage high amprage high freqency bridges are required ...  6 of them ..
i will use house wire ... for the ring ...  8 ga pulse   12 gage g6 wires ..
and i will post the ring winding configuration pics  soon !
OSIRIS
osiris
Quote from: nievesoliveras on December 10, 2010, 02:47:42 PM
Take this and use a good charging circuit with a voltage regulation runned by any one of the capacitors.
It could be a joule thief charger runned from one of the capacitors.
Just an idea!
Jesus
I must add that this configuration is in series and it will increase the farads.
The same idea but in parallel will increase the volts.
jesus can i kindly ask you to calculate  the farads of a single 16.2v cap bank useing 3000f caps
im still not a cap calculator .. so much ..  @16.2vdc i should have 3000f  is that correct ?
im baseing this clculation upon battery calculation forumlas for adding batteryies to a bank ..
ie..    i have 2vdc 1000ah batteries .. if i want 6vdc i will use 3 batteries i will have a total of 1000ah at 6vdc ...  if i were to increase the ah rateing of the bank it would require 3 more batteries and it then would be a 6vdc 2000ah supply  i have 14 of thease batteries .... they are made of glass .. and i have 120 more  on HOLD ..  20 year life expectency .. lead acid ...  ;)  o so hot o so cold ...  ;D
reserch charge and dischargeing methods of lead acid batteries ....  HOT COLD
i am selling thease batteries .. there 500 cdn each ...  the nice thing is ... they CAN BE REBUILT !  ;D  OMG then there good for 20 years more ..  they are used .. and in great  condition ..  they are used in the nuke plants as backup  power for the meters on the reactors...   should the power at the power plant ever go offline ...  i bet they were bairly used   ;)
THE MORE YOU SEE IT THE MORE YOU NEED IT !
whoa IS me
OSIRIS
i did say this ring is universal ..  wich it means it can work with standard electrical pratices or  non  standard
nievesoliveras
osiris
i built a heated / cooled storage room for the batteries ..  so i can warm them to discharge them and cool them to charge them ...   ;D
i have the entire room on a digital programable thermostat!  so i can sync the room temp to the charge and discharge cycle ...
i have a fork lift battery too in the room 12vdc 500ah currently at 12vdc i have 3 banks 1 500 ah and 2 1000 ah  2500 ah total ..
so my ring can replace all solars .. wind or other methods of battery chargeing .. it is in essance an altonator  this showen  ring can be configured  100's of ways !
fact !
OSIRIS
osiris
thank you
SIR JESUS
for your prompt work effort and time
the single ring design  i have designed for this unit is called the G6 spinner  it will make 3 revelutions per pulse .. resulting in very high freqency output  upon colapse the FLOW OF ENGERY REVERSES DIRRECTION!
so on a HAND pulse this is what takes place on a slow level so as ALL understand  my cap chargeing technoalgy  1 the engery flows down the wire .. b4 it gets to the end the pulse is CUT  the engery then switches the dirrection  of flow  in doing so it passes the g6 wires 3 times each then it is cut . and passes the g6 coils 3 times agin and lands in cap (BANK #2)
so each of the 6 g6 banks  get 6 pulses per 1 fire .  this is what i visualize   in my mind  as to the operation of said  designed coil..
OSIRIS
