Where should I be looking if I want to buy my PMA for a VAWT???
Started by StuartU, December 08, 2010, 08:20:33 PM
kampen
DO NOT BUY PMG at GINLONG (Chinese Garbage) see Youtube below:
Ginlong PMA The truth behind the REAL world output bs
http://www.youtube.com/watch?v=pneLbS0CFOk
BUY a DELTA made in USA (the BEST for Wind)
Hope this will be any help.
kampen
If you're looking for the highest quality low wind PMA available you have found it.
See below: Legend series are a larger, more robust PMA hand wound low RPM PMA.
http://www.hurricanewindpower.com/servlet/the-217/Low-wind-RPM-PMA/Detail
Mark69
Keep us informed of your progress, I always liked the VAWTs.
nueview
hi startup
i have done allot of generator testing and i am not into getting into any contests of words here over the ginlong generators verses gm pma's but i would give you a few points to consider as to the video posted about the ginlong being so inferior.
for the most part i will deal with the straight physics of the fields that will work within the two generators lets look at the magnetic rotor for starts the ginlong uses a non magnetic backing for the magnets spaced away from the shaft the gm uses the same pole pieces and buts the magnets around and along a steel shaft this steel going from pole set to pole set diminishes the field strength at the poles and the reaction of the field against the coils will force the field from the coils back toward the rotor center costing power to drive it and effency when in operation.
the amount of steel backing in the rotor helps to draw the field through the coil and steel will only hold so much field per unit of volume and as we are not talking Permalloy or another exotic material this lack of steel at the back side of the coils is a definite design flaw on the part of the gm pma promoter.
all in all it is a good salesmans pitch for a piece of garbage as he will not offer a testable dynamo graph of the power output curve which ginlong does and which i have tested has he done the same ?  NO he hasn't.
the bottom line is sometimes you get what you pay for or you just get ripped off.
Martin
