Selfrunning HHO system with 400 Watts additional output
Started by hartiberlin, December 23, 2010, 10:34:37 AM
Les Banki
Quote from: Marshallin on June 15, 2014, 04:14:00 AM
I am thinking about some small scale replica(some RC motor or realy small gasoline generator <1kw), but i have almost not experience in combustion engine field and not as much money to spare  :) .
Marshallin (and others)
Please note that the design of my Electronic Control Unit (ECU) for this project is INDEPENDENT of generator/engine size.
In practical terms it means that the ECU will be the same for a tiny engine as for a VERY LARGE one!
Thus, you are NOT saving anything on electronics by running a very small generator but you could save a little (not much) by making a smaller electrolyser.
For a LARGE generator, you could increase the size of the eletrolyser or have two electrolysers in parallel.
In my next post I will deal with the perceived "complexity" of my ECU design.
Cheers,
Les Banki
Marshallin
Les, stainless steel is stupidly expensive in my country so i want use old small electrolyser.
Is not powerfull but is power effective ... i sending picture from my thesis. I just need better case for that. Defenetly is not in my power to build some large 140 plate electrolyser so far.
I am quite afraid from large volme of hydroxy gas, i dont want to "play" with it, till i will get some experience. And i dont have stanalone workshop ... i am living in small apartment.
Is posible to run two stroke engine on hydroxy (If i will add standalone lubrication system to it of course)? Or i need 4-stroke one?
wistiti
hi Les
would you please point me the link of your pdf file.
Thank you!
Paul-R
Quote from: Marshallin on June 15, 2014, 07:47:17 AM
hydroxy needs the timng of the spark changed. advanced. With 2-stroke, you need to ignore one of the sparks, I believe.
N.B. For some electrolysers, staniless steel is essential for even adequate performance, and usually 316L is specified. do you have a recycling depot near you? They tend to collect metals separately and will have stainless steel. Scrapped commercial kitchen units are good, as is scrapped medical equipment
http://www.free-energy-info.co.uk
See Chapter 10.
cap100nf
Ok, thank you all for advice of program to use.
Kent /
