Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
conradelektro
@laneal: the pin numbers do not matter, they are just numbers to be able to talk about it.
You start winding the 21 layers in a direction that pleases you. And with "counter wound" I mean the other (opposite) direction.
So, the 21 layers and the twisted section are wound in one direction with a thin enameled wire. And the 6 feet starting at pin 4 (just a number, does not mean anything) are wound in the opposite direction with the same type of wire.
The winding with the red wire is done with a plastic insulated wire (just one layer) and is also wound in the opposite direction as the 21 layers.
Sounds complicated, but it is rather simple. Seeing the video helps.
Feel free to ask more questions.
Greetings, Conrad
lanenal
@conrad:
Thank you, that helps. And thanks to Taylor, now I saw the video  :). But I am still a little unsure about how to connect things together. You see, when you wind the coil, you first fix one end of the wire (let's call it the starting end) to the bobin, then after winding the whole coil, you fix the other end (let's call it the ending end) to the bobin. So what I am not clear about is this: in the diagram you draw for us, which pin # is for the starting end of the coil, and which pin # is for the ending end? If you could label that out on the diagram, I believe it would be great to go with the video and help people replicate this. That's also why people use dot notation to have the coil polarity labeled out on transformers (if current flows from the dotted end to the other end, which is not dotted, of a coil, the induced magnetic field would be in the same direction as when the current flows in another coil on the transformer from the dotted end to the other).
Maybe I missed something in the video, sorry if this is apparent from the video. Have to go now. Good luck with your replication!
lanenal
ltseung888
Quick Summary of the three Divine Revelations
Revelation 1 â€" Bringing-in kinetic energy of air molecules.  This is the simplest of all the experiments and such experiments have been done thousands of times already.  Strike one tuning fork.  One or more identical tuning forks nearby will go into sympathetic vibrations.  The resulting sound is louder and last longer.  The extra sound energy comes from the kinetic energy of air molecules.  Resonance condition is required.  At present, this Revelation is used for theoretical understanding.  No product based on this Revelation is planned.
Revelation 2 â€" Bringing-in gravitational or magnetic energy.  A horizontally pulse-pushed pendulum can bring-in gravitation energy.  The COP for small angles is approximately 1.5.  So long as there is tension in the string, gravitational energy can be brought-in.  If we replace the pendulum bob with a magnet and place other magnets around, we can bring-in magnetic energy.  Magnetic energy is better because it can be greater, have different directions and can be turned on or off.  The oscillation can be replaced by pulsed rotation (resonance pulsing).  The secret is in the exact turning on and off of the pulsing that depends on the load.  Precision engineering and computer programming is needed for best results.  Examples include Tong, Newman, Bedini, Adams, Wang, Liang, 225 HP wheels, etc.
Revelation 3 â€" Bringing-in Electron Motion Energy.  We can use LCR circuits to produce resonance or oscillation circuits.  A LCR circuit can be thought of as a tuning fork.  We can have multiple LCR circuits in resonance and electron motion energy can be brought-in.  The use of two oscilloscopes to display Input and Output waveforms and Power simultaneously is best.  Examples include FLEET, Joule Ringer, Steven Mark Device, Stan Meyer HHO generator, Rosemary Circuit etc.  This line of products is expected to mushroom quickly as it has no moving parts and the size can be much smaller.
With the three Divine Revelations, the mystery of Bring-in Energy devices is clarified.  The water has been turned into wine.  We just need more servers to interpret and produce products for the Masses.  Amen.
http://www.energeticforum.com/renewable-energy/7434-lee-tseung-lead-out-bring-energy-theory-4.html
The theroy is complete.  Enjoy your experiments. ;)
lanenal
@Conrad:
@lasersaber:
After carefully reviewing the video sent to me by Taylor several times, I have been able to pinpoint the pins 2,3, and 4, but not 5 and 6 (which I provided a guess). Please see attached and comments are welcome!
Now I am glad that the polarity of the coils as revealed in the video should agree with the dot notation I have provided a while back (see post http://www.overunity.com/index.php?topic=10179.msg275610#msg275610).
cheers,
lanenal
lanenal
Hi,
I have two entry level questions:
1. How do you generally make a bifiler? do you first twist the two wires before you start winding?
2. How do you prepare the CFL? Do you rip off the circuits inside the CFL first?
Thanks!
lanenal
