Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
Lattice333
@LaserSaber
Congratulations Lasersaber - amazing circuit - never seen anything quite like it. Love your work. PTL  :)
I have replicated and it works just as you show on your videos. Mine will run 15w CFL dimly for 10mins after disconnecting the power source.
@Everyone
I deviated from LaserSabers coil and used a prewound Bedini trifilar and 15000uf. When I have time I will wind a coil as suggested.
There has been alot of speculation about the schematic on this thread. Attached is my version of the schematic together with LaserSabers original drawing. Enjoy. I hope this helps other replicators.
Be encouraged everyone!
Jonathan
Omnibus
@Lattice333,
Can you place your device in a Faraday cage and see if it will work the same way? Let's get this out of the way.
Lattice333
Quote from: Omnibus on January 06, 2011, 02:29:44 AM
@Lattice333,
Sure. I dropped the circuit on a dinner plate and placed it in the microwave oven. Ran just as easily inside the microwave with the door closed.
Lattice333
@Everyone
I tried changing from my 15w spiral CFL to a smaller 8w spiral CFL. The smaller CFL would not light at all and I could hear the HV arcing in several places on the transformer.
I then switched to a larger 25w spiral CFL and it worked best of all. I could then raise the starting voltage higher before arcing began. Also it was brighter and ran for 16 minutes after the power supply was removed.
If you are replicating please try starting with 15+watt CFL. I think the circuit sees a small tube diameter as a resistance. Lasersaber got it to work with a small CFL in the video but his coils used much finer gauge wire than my Bedini trifilar (0.8mm) and probably generate a higher voltage to overcome the additional resistance that a small CFL presents.
I have attached a revised schematic.
Hope this helps!
Jonathan
Omnibus
Quote from: Lattice333 on January 06, 2011, 05:17:43 AM
Great. Thanks. So, now we have to worry about the power balance. What order of magnitude are the current and the voltage, can you tell?
