Joule Ringer!
Started by lasersaber, December 29, 2010, 02:19:43 PM
gadgetmall
Quote from: nievesoliveras on January 08, 2011, 11:20:57 AM
@gadgetmall
What does it say on the words at the secondary coil?
Jesus
Hi it says to LEDS -- EXTRA POWER .. it could go to a bridge i suspect also . thank you Jesus .
Albert
kooler
ok
i final got a fuji transformer that lights a cfl bright and it was the camera everyone told us not to buy..
and it will do 40 ma's with a 9 watt cfl.. and it is the AAA battery camera.. it has a ver small transformer in it..
i strip off every thing on board and breadboarded it and it work perfect..
now i can go back to working on this lasersaber thingy..
i also found a awesome transistor.. i was stripping some laptop psu's down and found it..
it is a 2sc2334-y  works good for low volt and current or high power.. its a to-220
i was running 12 volts thru it with my other device with no heatsink..
sorry if it is off topic..
robbie
nievesoliveras
@gadgetmall
I do not understand why you say that it has no bifilar, when the toroid is based on a bifilar winding.
But here it is,
Jesus
gadgetmall
Thats it! I appreciate you Jesus , thanks . I meant no lasersaber bifialar(air core) when i labled it that and i know i have a weird way of labeling stuff but it was someting i could remember . .The only thing is different on your art is i use 5 germaniums but if someone wants to build it they can try as many as they like . This one has ran over 40 hours and still running a CFl light  . there is something to his discovery as adding another coil really does reduce or recycle the power needed to run it with good light  . I noticed on another one i am making using air core coils i made after it starts i can dissconnect the collector and one wire from the top germaniums bifialar connection and it still lights a neon on one battery . . I really do not undrestand that at all. .i see no way it could still oscillate without those connections unless there is some serious capacitance in the coil and the circuit board i am using .  .
Kooler glad you are in the ballgame now . I am using aaa fuji also . i just got two old aa fugi circuits in a pack of two cameras. they have the neon. but havent tore them up yet . One aaa fugi will not light the cfl and its hooked up exactly like the one above but it lights a neon .  . there must be a defect in some of the transformers or it need more primary windings . I am having a blast messing with it because i beat my old time running one on an single cell. The c battery i have is rated 2500mah and so is my aa battery so the size of the battery dosnt matter if they are rated the same . When the power goes off  i'll have good light . It goes off a lot here as i am far away from a town and there is still lots of trees hangingon wires for miles . I don't think they will ever run high speed internet here :(
Albert
resonanceman
I have been trying to understand what is going on in this circuit.
There is alot I do not understand about how it works
I do have a theory about the string of leaky diodes.
In my opinion the string of diodes is just raising the inductance so the impulses can do their thing.
If I am right a LED array of the right size might work well
A small high voltage capacitor might work well too. (probably less than  .1uF )
I have 3  AA camera circuits from E Goldmine somewhere around here .
When I find them I will give this circuit a try.
gary
