Bob Beck Protocol for curing AIDS and Cancer
Started by matthew6060, January 05, 2011, 04:18:04 PM
CompuTutor
Quote from: the_big_m_in_ok on January 06, 2011, 11:14:41 PM
The Overunity link runs, but the sub-link to the French page is broken:
http://172.16.254.163:15871/cgi-bin/blockpage.cgi?ws-session=1644316490
--Lee
Um, I didn't post a second "sub-link" with that address,
worse yet is that the ip range is a non-public internal #
The Verizon pool is in Ashburn, VA, USA...
http://en.utrace.de/whois/68.238.107.38
http://ip-whois-lookup.com/lookup.php?ip=172.16.254.163
http://dawhois.com/index.php?query=172.16.254.163
May I ask for more information as to where you obtained this
so I may contribute a better answer please ?
Thank you
TheOne
I buy some of the electromics needed but i cannot fond the LM358chip so far and where you can find wire of silver.9999?
Bob Smith
You can buy .999 silver wire through Sota Instruments. Here's the accessory page where it's listed:
http://www.sota.com/default.aspx?page=608
If you can't get in, you might have to go to their main page and log in as a guest.
B
TheOne
thanks for the link
They cost a lot , i try to find on the web and find out other cheap 0.9999
http://www.atlasnova.com/SilverWire.htm?gclid=CJO3wM-8qaYCFRZ-5Qod1Us3pQ
http://www.ccsilver.com/silver/superfines.html
I was thinking buying in a shop but i think its more pratical to buy them from the web unless otherwise
MrMag
Quote from: truesearch on January 07, 2011, 09:45:23 AM
@MrMag:
Would you mind posting your schematic? I'm interested in this Beck/Rife kind of research ~ would like some help after 35 years of being a Type 1 diabetic. . . .
truesearch
Yes, that is the document. You are better off using the "improved schematic". The IC being used in it is just a dual 555 timer. It should be easy enough to get.
As far as making the silver solution, there is a cheaper method to make it. If you have some old silver dollars hanging around you can use them. Some of the older ones are 95% silver or higher and the remainder is copper. The copper is good for you too. All I do is hook them up to a couple of jumpers and a 9Volt battery. Hang them inside a glass and fill the glass with water up about 3/4 the way to the top of the silver dollars. Make sure they don't touch and just watch it until the water becomes a little milky.
