Throwing ideas around, mumetal and diamagnetic materials
Started by V-Spec, January 26, 2011, 03:31:33 AM
V-Spec
CLaNZeR - i have seen your many replications, any of them made and tried with diamagetic materials?
exnihiloest - this seems to be the force im missing, the magnets on the rotor attracting to the corner / edge of the ferromagnetic material, i didnt think that unless the magnet was touching the ferromagnetic material that the attraction forces would be any more at end of where the mu-metal stops.
Will the mu-metal become magnetised even if the magnets are not touching the metal and therefore the magnets attract more to where the mu-metal stops and the diamagnetic material continues? I thought the magnets would attract and it would contain the flux on either side. Is this correct or will the flux lines be focused and attracted more to the corner of the ferromagnetic material on the edge, i think this is what exnihiloest is saying? any one else care to explain and help me understand.
i know the field of each magnet will always loop but extended the thickest gradient part of the diamagnetic material past the mu-metal to cancel the forces.
maybee i need to upload a picture of this critical point to further understand whats going on
or use a high permiable material shield with different hysteresis, coersive and magnetostriction properties.
any thoughts?
V-Spec
jus thinking out loud, learning with expierence
any materials that are highly permiable but non ferromagnetic?
any way to naturally or electrically augment the flux of a permanent magnet?
Rich
V-Spec
stefan?? im just a guy trying to make a magnet motor, can mods please delete?
translation:
Hi Stefan,
so slowly you make a fool of yourself in your own forum!
Also you have already postulated a lot, even with video, but nothing
stayed away because the evidence used for OU.
What struck me in recent years with you, you begeisterst
up again and again for something else, sometimes there are levers, sometimes it has
to do magnets, in between there was time HHO, it was just
Capacitors, and now it's the water ....
When dealing with so many things, nothing can with rum
come, it is better if you work hard on a project
convinced of the one is.
How many things have been posted here already, without evidence, why have
not you deleted?
I just saw that again entries were deleted, but listen
finally with the manure, thereby destroying the forum and the
Truth!
You even post but 3x the same crap, and delete the image!
Your forum lives of OU or PM discus ion, was glad that a lot
The discussion has, for a real PM sobalt the world sees is
your forum dead
Of course, one comes to expect more, you can calculate everything,
but if you do not know what you like to calculate, because
not understand the connections, it can not.
You may like to delete this post also lock me out of me,
let me not prohibit the mouth and such nonsense as
@ Pp posting I can not cover.
In contrast to Wunderlich (pp) I do not need your forum to
To advertise because I have studied what this "stupid" person.
If you and makes pp @ common cause, there are 15,000, - from
Forum, 40000, - by Wunderpiss, so you have 7500, - OU, reflects
a nice holiday with the World Cup.
Instead of the video link on the home page I would write in bold type:
Here's Wunderlich law, I obey only him!
PS: You just can not shut up, you've blocked me
because I wrote the truth that you do not want to read,
I sign up faster than you can block me and
will always post the text so that everyone sees as
coward you are!
gravityblock
Quote from: V-Spec on January 30, 2011, 09:48:09 PM
anyone with experience melting and using bismuth and pyrolitic graphite in shielding / canceling application.
Rich
CLaNZeR making some Bismuth Toroid Cores, http://www.youtube.com/user/Seacrhing2008#p/u/45/NZF1FYaEdqc
GB
aidrenegade
I don't know anything about mu metal but when I asked a mu metal company if shielding one pole of a magnet would increase the pulling power of the other pole (in effect make a magnet stronger) they said no and sent me this pdf paper on the subject.
