Anton Glotov's Gravity Wheel
Started by Omnibus, February 04, 2011, 12:20:45 PM
ramset
Omni
I want it to be that simple! Please let it be that simple!
;D
do you have a number we can call?
Chet
Thanks Grandma
Omnibus
Quote from: ramset on February 04, 2011, 02:44:36 PM
Omni
;D
Chet
I guess you'll get the number to call from here: http://www.zungedesign.ru/projects/?item=133 . Let us all know what happens after you call them.
e2matrix
I've seen this design before somewhere and thought it certainly looked like it could work.  I almost built something similar one time but never got around to finishing it.  I think the black end pieces are to keep the arms from falling too fast which would likely cause damage eventually to the hinges or attachment points.  My one concern though is that since weight is equally balanced on each side will gravity act on the open arm in such a way as to leverage that weight because it is further from the fulcrum point?  Or does this simply work because of the increased speed and inertia that occurs when an arm flops down?
ramset
Did you write that tongue in cheek?
   Ð'изуальная бижуÑ,ерия, леденцы для глаз / Ð'лог / Kindisch / СÑ,удия / Адрес / (+7 495) 799-3470
Ð'се проекÑ,Ñ‹ / PDF-Альбом / Ð"раÑ,,. концепции / Ð"екорации / Журналы / ИллюсÑ,рации / ИнÑ,ерьеры / Книги и буклеÑ,Ñ‹ / КомпакÑ,-диски / ЛогоÑ,ипы и сÑ,или / ПлакаÑ,Ñ‹ / ПригласиÑ,ельные / СÑ,енды / ШриÑ,,Ñ,Ñ‹
Сцена для вечеринки на заброшенном заводе
How do I dial that   +   in the phone #?
Chet
Thanks Grandma
e2matrix
BTW does anyone think this would spin faster with less arms on it?
