Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
Bennyboy
Mate, I'm looking at your picture, am I supposed to see half a man there somewhere, coz buggered if I know what I'm looking at.
Is it just me or do most of these pictures you post have nothing but landscape on them?
Please enlighten me!
Koen1
Yes, I also do not see any men with yellow hard hats, nor do I see any forklifts...
Are you sure you're posting the right pictures to go with your secriptions?
Also, I visited chemtraicentral but there's only lots of stuff on chemtrails,
I don't easily find anything on the mars pics you're so anxious about...
Perhaps you can more clearly indicate where we can find these pictures
and where we must look to see these men with hats etc?
Don't think I'm dissing you or anything, I do believe Nasa has been
forging pictures and colours to keep us from the truth, and it simply
does not make any sense to spend billions to get to the moon
and then not take that last step toward Mars... So it is very well
possible they have been there since the 1960s. After all, they've got
huge underground bases in the US, and although hauling the stuff
to Mars is quite a bit more difficult, once you've got it there it should not
be excessively more difficult to build your underground base there...
A typical false argument opposing that has always been the fact that
Mars does not have a proper atmosphere. Well, maybe not on the highlands
where the probes generally land, but what about those 5km dep canyons?
That's quite a depth, and we know that the bottoms of our Earthly canyons
(on the ocean floor) have significantly higher pressures... It is not impossible
for atmospheric gas pressures to be significantly higher on the bottom of
those canyons. And of course it is easy to drill into a canyon wall to start
an underground complex. And you'd be hidden from view too, way down there
on the bottom. You'd just need to build a topside communications link I guess.
So perhaps that's what the topside buildings are for?
Bulbz
I also believe that a lot of the pictures are put there to keep us busy while the government play around with the big stuff.
What I am saying is... For a mission that is supposed to cost billions to achieve, they seem to have fitted some seriously crap cameras. I reckon that they use an extremely high quality camera for their own stuff, and use a crappy camera to release stuff to the media. Either that, or there are actually humans up there, which would eliminate the need for decent lander cameras.
Best regards.
Steve Ancell.
raburgeson
The only way I can clarify the no teeshirt is crop it down even further so here. And the fork truck is clear, I don't know maybe try a different contrast and brightness on your monitor. Get 5 People in and ask them if they can see a fork truck and don't tell them it's Mars. Bet you don't have a problem finding it then. Man with his back turned to you below.
I'm using a 21 inch CRT IBM monitor set brightness and contrast at default. I can see it clear.
Bennyboy
That's a negative.
Whilst I'm sure things are being kept from the camera's or airbrushed out, I don't think you're on the right track here mate.
