Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
Bulbz
Quote from: Bobbotov on July 02, 2008, 01:26:19 PM
Duh, that's one of the Martians.
Well then tell them to change their fashion sense, they look like tourists :P.
Best regards.
Steve Ancell.
Koen1
@Bobbotov: I don't get you, dude.
First you give me and Groundloop a lot of shit about us being delusional for having a bit of fun here,
and now you are doing exactly the same!
Why did you feel the need to give us a hard time about something you have obviously discoverd is indeed fun?
raburgeson
It's the viewers guys, I just put in ACDC pro2, It can't do it. I'm using Photoshop 6, I've noticed Paint Shop Pro does show you some of it but, not as well. I haven't tried others yet but I suspect they aren't near as clear either. This crap is there and I'm stuck on some things too, like 2 ponds in the picture or are they? Is it 1 pond with air brushing separating the middle of it? When you can see this stuff clear it's still confusing in spots. Well throw the images on disk an visit a friend that has Photoshop, it could be they used this program to do the dirty work.
I will try other viewers if I can find them with trials, I have over 2 grand tied up in Photoshop and am not going to buy a bunch of others. We got some interesting results in Windowsxp paint. It showed a couple of spots fairly clear.
I would be ribbing myself if all I saw this with was ACDC. You can't see anything with it and I don't think trial mode has anything to do with it. You don't have to own Photoshop just have access to someone that does. I'm sure they will look at it with you. Even a student at a commercial art school or something would be interested if you tell him why you want to look. I can see it on a lcd and crt here. 2 different video cards, one is hi-def and the other is a Nvidia, as long as the monitor is clear the results are good. Oh, the lcd one has Photoshop 8 CS2 on it.
I got shock and awe the first time I hit 700% zoom, it wore off. This crap is there you just aren't seeing it and the viewer you are using is probably what is letting you down. Things to clear the picture.
Try equalize on it if it's red, you can undo in edit if that doesn't do it. Then try auto levels, and in some cases on some of these photos use both, equalize first. That's simply all I do to these pictures then I play with the contrast and zoom. Raising the contrast some helps get rid of the transparent stamps, so they don't fog the picture. Most of the seeable stuff that matters is around 700% zoom on every picture I've looked at.
Ive looked over more than these 2
Husband Hill
Larry's lookout
Victoria crater
Home plate
Olympus mons
Twin Peaks
Two Tone Rock
East Hills
Missoula Crater
West Valley
Horizon Hills
Cydonia
Endurance Crater
Bonneville Crater
To name a few plus a number Panoramas, sol, and PIA pictures from large to extremely  large.
Remember I said there is no face there are roads on that feature and they are being used.
Do you remember the saw teeth at the bottom, they tip the camera to screw up your perception of level.
Then they have problems putting the complete picture together. Look at a civilian panorama, everything fits together perfectly because the camera is level on a tripod. Wake up.
Koen1
Yes I remember. I just still don't see the stuff you're seeing.
Doesn't matter if I use photoshop, if I look at them on a widescreen
full HD, if I adjust the colours, zoom in 700%+, nothing of that
makes me see anything like roads in use (which I assume means
you're seeing traffic on the roads?), stripmines, forklifts, etc.
I don't doubt that you truly believe you are seeing them,
but I can't make out anything more than blurs and certainly
nothing that clearly looks like vehicles or anything... Sorry :(
raburgeson
No, I can't see traffic, I can see clean roads, no rocks on them nothing they are clean as a whistle. Did you find the open area with the 2 trees in husbandhill_spirit_big? The trees should be about 1/4 inch high at 700 zoom. I'm sure the Chinese have done this by now so you can do it. The roads you first find go down and to the right, 2 of them. Follow them down and find the parking lot. The truck on it isn't clear but it's backed up to a building. The building is just a fuzz. That fuzz needs cracked out of the picture, I'd give a lot to find out what viewer shows this clear.
I have a better question, why are they working so hard to hide water? Maybe people will want to go there and they won't be able to rob the place in peace? Windowsxp paint shows the truck better and doesn't show the building at all.
Tell me you can't see the buildings on the horizon.
