Mars color
Started by raburgeson, May 22, 2006, 06:55:24 PM
raburgeson
Alright everyones fighting with pictures that are modified by airbrush, I'm going to show you something. I'll fight fire with fire.
I don't monkey with peoples minds. I modified this one crop out of being curious of what would
happen. I repeat I modified this. The results were amazing, I'll give you every detail of
the changes I made, When I do it to you I tell you, I'm not like the other side.
First I used auto level on the picture. Then I chose a water type flat area, it was yellow.
I replaced 5 of the colors in the flat space with any yucky blue and one light green. As
users of Photoshop can tell you Hue, brightness and shade is a terrible way to select a
color replace but that's what I did.
I backed out to 600% and searched the picture. Suddenly the tracks from the rover looked
right. The water that filled them answered so many questions about them I thought you should
see this. The puddles look right everything looks right. The whole picture didn't though.
Different light from different parts of the day and different airbrushers working on
different parts of the picture Make things different for the picture as a whole. A very
large part of the picture came out though.
I cut the crop at 8084 X 2450 from the lower left corner. It was to large so I reduced the
image to 7000 X 2131 so I could include the raw data in the same rar file. The color replace
was set at 50% defualt tranparency. I can't think of any other settings.
The raw crop I simply canvas sized it to 8084 X 2450 and reduced it to 7000 X 2131 so they
would have the exact same information in them size wise and view.
They have been doing this to you for years, let me do it once. I'd like to think there would
be a compromise but I don't think so because the tracks are so perfect. Well take a look, it
doesn't look dry up there after you see this.
http://rapidshare.com/files/128499898/RawAndEdited.rar.html , for the crops.
The source files name was everest_spirit_big.jpg. You can get it here. You need the whole
file to get autolevel to work the same. Remember to click the plus magnifying glass on the
picture before saving.
http://www.phys.ncku.edu.tw/~astrolab/mirrors/apod/image/0511/everest_spirit_big.jpg
They have been getting away with this crap far to long. I'm not the only one yelling foul either, search and see how many sites say the rover was stuck in the mud.
raburgeson
Progress report. I have made progress studying the picture. The pipes (most of them are disinformation) are not pipes, they are cement cylinders. Poured into tubes of a reinforced plastic tube form. They do this right here on earth. I have a picture of cement cylinders I got right here in Erie along the lake front. They are using these to control the flow of water. I had a problem because the water flowing from the pipes never seemed to match up with the pipe completely. If there is any pipe in the picture it would be hard to identify which ones are actual pipe. I measured the cement cylinders on the Lake Erie shore and got 3 feet thick and 4 1/2 feet wide. I have no reason to believe the ones in the picture are smaller. This makes the crater larger than claimed. It also leaves a believable size for the building at the crater rim of 16 by 20 feet with ten foot high walls. This would also include erosion control. Those airbrushers are a bit better than I was giving them credit for. I will post the picture of the cement cylinders at chemtrailcentral.
Bulbz
You never know... Maybe somebody is doing a lot of work on Mars, ready for when the space tourism age starts.
Best regards.
Steve Ancell.
utilitarian
Quote from: raburgeson on July 17, 2008, 07:21:27 PM
How do you explain NASA leaving the pond of water clearly visible while making great effort to airbrush rocks and other irrelevant objects in the same photo?  After all, liquid water is not supposed to exist on Mars, based on everything NASA has told us.
Koen1
Well it's easy to say "that's not water, it's just sand dunes" and show a picture
of typical wavelike Safara sand dunes, and to follow it up with "and besides, our
Viking landers and Yaddayadda measurements all show there is no water on Mars.
So that stuff on the picture can't be water. So it's not. It's just sand.
Nothing to see here. Move along."
but it's less easy to say
"that's not water, it's sand. And that's not a drain pipe, it's a rock. And neither
is that coke can a coke can, it is also a rock. After all, our Viking landers never
spotted any coke nor drain pipes nor water, so that stuff can't be there. Q.E.D."
so they need to remove the drain pipe and the coke can from the picture which
they do by blurring it a bit in a rocky colour, and they paint the water with a
sandy texture and voila, a perfectly unsuspicious patch of wavey sand dunes.
