Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
Super God
Just to verify, when we take it out of the freezer (before reflux) we put the flask in room temp water. Then, assuming I don't have a condenser, I would tighten the rubber stopper and apply heat to the flask until it is at 60C for 2 hours.
Sounds easy enough, this is the only step that caused me to stumble a bit, once I do it Im sure it'll come to me.
>9000
e2matrix
Quote from: The Power To Be on March 07, 2011, 02:43:07 PM
Good job Romo.
Ramset, EF forum, FCR etc and those Standing Tall.
There is no Religion being marketed here, As I do not subscribe to Organized Faith where
Man is robbed of his intelligence in exchange for Beliefs without Proof.
You can NEVER understand the Forces of Nature if you DO NOT UNDERSTAND yourself first. It is that simple.
How can you liberate water Gaseous fuel without undertanding the Aether bond that holds bind in the first place. And you will not know the properties of Transmutation if you do not DO the experiment. It is not taught anywhere, WHY?, because NATURE is abundant, everything is right infront of YOU!.
How can you harvet the waves if you DO NOT KNOW the properties of the body that moves in the water, creating others motion in perpetual and continue until the limit of material space and immensity.
You can not use Math here as you will wander off with infinite equations that holds NOT a single FACT to Reality, The only way for you to LEARN is by doing the Work and Observing, BY YOURSELF ONLY, use your own intelligent, other interference  will only hinder the  the progress. Differrent Phases of Water, from making Water Fuel to Cold Fusion and many other fascinating possibilities.
Tesla described relativity as "a beggar wrapped in purple whom ignorant people take for a king."
Beginners, this is a Good Read.
"Occult Ether Physics". This book is dedicated to the rediscovery of, examination of, and the integration of these secrets into the public knowledge. Because of the last 76 or more years of progressively intensifying false propaganda and manipulation of knowledge and science, a majority of
scientists ridicule the concepts of the existence of an ether and of flying saucers, as if such thinking belonged in the category of a "flat earth" theory and the "little green men" from outer space babblings, but the reverse is true.
The proponents of Relativism and the Big Bang (the "Big Bangers") want you to believe that the universe is finite, so that, if you go "too far", you will "fall off the universe", rather than off a "flat earth".
What's the difference? Flat earth...finite universe...they're both dumb theories.
And what do the "little green men" lies have to do with exclusively man-made electric flying machines, and technology based on sound and well-established electrical science and physics, but  which, like the existence of the ether, has been tucked away in secret vaults, to keep you from using
it, while you are being fed false and useless "theories"? These range from "curved space", "time travel", "Big Bang", and "alien abduction" stories, to "parallel universe", "interdimensional travel", and any other
outrageously incredible stories, concocted by government spooks, national security personnel, and secret agents in the "UFOlogy" and "pseudodebunker" communities ("pseudo-debunkers" in my vernacular, are official government spokesmen or scientific know-it-alls whose job it is to completely deny the existence of flying saucers, or to ridicule their other covert government counterparts, the UFOlogists, new-agers, or
paranormalists).
The book powerme refers to above 'Occult Ether Physics' by William Lyne is indeed a good read as well as his other book.  You can get it right here in the downloads section : http://www.overunity.com/index.php?action=downloads;sa=view;down=404
petar113507
Quote from: Super God on March 08, 2011, 01:15:06 AM
If you don't have a reflux tube -- you're going to want to watch out for pressure build up.
I would suggest a cooling mechanism of some sort on the top of a flask -- or maybe a failsafe "pop top", so that the glass/flask doesn't explode.  :o
I don't want anyone getting hurt by being careless (by not calibrating/compensating for the pressure build up), Please be careful. :-[
The Masonry jars worked beautifully, because they are pretty pressure & heat resistant -- Plus there is a large space in the top of the jar for the gas to cruise around on top.
I used a bag of ice atop the masonry jar (was not my idea though) -- and the metal lid allowed the top to get rid of heat pretty well.
For your 'hiccup' in the process, The reason you would take the flask out of the ice water -- and let it sit in the room temp. water for about 5 mins or so, is so that the flask does not shatter from thermal shock.
==Romo
ramset
Thanks Grandma
ramset
WOW
I apologize to all involved here!
I did not understand this is Two threads on two different Forums [these things happen]
Thanks
Slovenia
A special apology to Powerme!
EF
Link[from Romo]
http://www.energeticforum.com/renewable-energy/7365-discussion-best-way-use-heat-hho-generate-electricity-16.html
Thanks Grandma
