Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
The Power To Be
great
job guys, we're almost there. RAD, what caused your poor result?
fishman, What binds H2 + O, that is what you need to control,  What is it?.  It's the link that connects everything, When you understand, then you will Know that there is no seperation, dividing knowledge into seperated fields of studies will only confuse you more.
You will only Learn more if you Know who you are first, Do not wait for your Death experience as it will be too late.
MasterPlaster, Give Man all of the Technologies of the World and it will NOT change a thing. Many great men have tried, their efforts were fruitless as common man could not understand and never can see any significances and their findings buried deep. It is not about Technology, Findings etc. etc. It is only about YOU, yourself only and what you Value.
This water fuel project is not important  any sane person can make crystals and produce piezoelectric water fuel with many different kinds of elements. It's primitive technology, explosion, noise, deterioration etc., sure you can run your car on water and travel or run a genset to make electricity, it is a good start but what is it worth to you?.
Chet, you said Knowing takes the Fun out of Life but Knowing that you know nothing is what Life is all about. Man will not lift a rifle if only he knows his virtues. Knowing is not important, Clear Perception is.
What you VALUE is what counts, nothing else. We would happily be trading sticks as legal tende if that is what's valued. Paranoid is a natural defense.
“The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.” - Nikola Tesla.
"Civilization is a limitless multiplication of unnecessary necessities. Every civilization carries the seeds of its own destruction, and the same cycle shows in them all. " - Mark Twain,
"Education is the transmission of civilization." - Ariel and Will Durant
"The more rapidly a civilization progresses, the sooner it dies for another to rise in its place." - Havelock Ellis, The Dance of Life
"Civilization begins with order, grows with liberty, and dies with chaos." - Will Durant
"In the souls of the people the grapes of wrath are filling and growing heavy, growing heavy for the vintage." - John Steinbeck
RAD-HHO
Quote from: The Power To Be on March 08, 2011, 05:25:40 PM
great
I'm not certain, but I'm pretty sure Its was because I did not keep my temperature a constant 60 degrees C.  I believe It went a little above that.  The jar fogged up and the ammonium reacted with the plastic lens on the $2 thermometer I got from walmart. The lens frosted up and I could not read it anymore.  I had it  in a water bath, the water never boiled, so it did not  reach 100.
Rick
The Power To Be
great job RAD,
ZnO has many phases, too hot above 80 C and you will have forced hydrolysis where NnO structure is different.
How did you test?.
I have used clear tupperware shoebox $2 with a custom vacuum molded plastic lid, In the lid  I build in vent port and pump mount, any  polycarbonate from hardware store works. Plastic molding is cheap good prototyping material, oven plastic and mold over vacuum chamber, only shop vacum is needed. Don't ask me, it's common knowledge.
I also used the above gadget to inject atomize water into regular ICE with E3 plug, BIG gas saving!.
RAD-HHO
Quote from: The Power To Be on March 08, 2011, 08:43:12 PM
great job RAD,
How did you test?.
I used a Lock & Lock tall square food storage container.  I just put the crystals or ZnO which ever it was in a large coffee filter and placed it in the container with the fogger.  I then placed the E3 plasma spark plug in the fog and fired it.
Thanks,
Rick
