Practical Method for Production of Water Fuel with Piezoelectric
Started by The Power To Be, February 17, 2011, 06:11:02 AM
The Power To Be
Hey Slovenia
Thank you for your continued support.
I am not very familiar with Schauberger but found some articles while I was researching acoustic cavitation. All we are working with is Waves, common electricity is a dense long wave. Sonofusion is no more than concentration of short very rapid waves.
A lot of people are stuck as they still rely on modern knowledge to proceed, you do not need fancy meters to measure frequency etc, the transducer is your converter of DC to waves, alter the caps, that's all you need to do. Use a baloon to collect HHO and do simple calculations with timing to determine frequency, or just observe the ICE combustion and adjust your gas accordingly.
What we have at our disposal is much more far advance then what Tesla and Schauberger had utilized, yet no one can replicate their result. It is not what that you Know or Have, it is simply using your common sense to see what you can make and Have.
Get the water fuel going and you will understsand the steps needed to transmute water into the next phase that yields sonofusion, it is simple wave and cavitation effects.
Have a good day.
Slovenia
He need to find a good source for brass bowls for our receiver and brass acoustical horns for our piezo pond fogger to be mounted inside.  I've come to the conclusion that a simple brass bell of the proper size would probably work really well for the acoustical horn, while the brass bowl will need to be the normal configuration of a bowl.  There are many Indian imported brass bells and bowls.  We need to find a good source for our experiments.
I'm looking for them right now.  If anyone knows a good source, please share the information.  Thanks!!
I have designed my chamber while I've been waiting for my ingredients.  So, I'm chomping at the bit to build this cell.
I'm going to make mine out of pvc.  I got to thinking that the tube should probably be a clear acrylic for our experiments, so that we can see what is going on inside the chamber and take pics to share with the other members of the group.  So, that is what I intend to do.
altrez
b_rads
Check out post #1 here.
http://www.energeticforum.com/renewable-energy/2146-water-disrupting-spark-plug-keely.html
octavian posted this on 6-18-2008:
The following was from a post received on 12/20/97. The names have been removed for privacy.
"A friend of mine, suggested modifying an ultrasonic humidifier (replacing the frequency tuning resistor with a variable resistor) such that it could be adjusted to operate at the 42k frequency requisite for the separation of H2O into it's constituent parts (I haven't tried it). The power level of the humidifier may be inadaquate for the job, however."
