Free Energy:
Started by BushWacker, April 08, 2005, 02:21:39 PM
BushWacker
Yes Paul,
    Here are the links that Stefan provided. Both sites have the video's, but the first/top link has the better quality video's. I believe Stefan cleaned these up for us a bit from the initial copies but otherwise they are the same. Also, myself and several other's have had problems viewing the files in (.avi) format for some reason, so if you download them and change the format by simply typing (.mpg) or (.mpeg) in place of the .avi at the end of the file name, you should have no problem viewing and/or saving them for your referencing. They are also safe and clean by the way.
Cheers,
Bush Wacker
Shumann Resonance Coil Links:
http://ntint.ntinternals.net/
http://www.harti.com/coil/
Bearded Guy in Video of Shumann Coil is - Steve Marks
Last known Location - Anaheim, CA 92801- 3802
BushWacker
Hi Guy's,
? ? I just wanted to add, that after close visual examination of the exposed material on one of the Shumann resonant coil configurations, I believe strongly that the coiled laminate ring material is most likely a Metglass product, very similar and possibly identical to the material that has been recommended by Jean Laudin on his old MEG site. If you look closely, you will notice that there is an upper and a lower laminated ring. My guess is that this is the equivilant of Tesla's double wound coil which he used in some of his atmospheric/radiant energy experiments. There are also two cylindrical metal casements in the center of his large coil, which are likely crystal resonator's/piezo electric devices. It is a wild guess of course but, I believe that he is using a modified radio tuning device to tune in to the Shumann frequency since the size of the device is much to small to correspond directly with a field coil that would be needed to directly resonate at 7.43H. Also it appears to me that he is using the piezo crystals to modulate and jump up the frequency before routing the resulting frequencies through the secondary coil in the case of the large unit. He is possibly doing something similar with the smaller unit and using the Metglass type laminated core/coil in place of the double wire wound large coil. This is only an assumption and I am just trying to identify the various parts which are shown in the photos and videos which are currently all we have to refer to. If anyone else can positively identify any of the components which appear in these visuals, please let me know so that I can try to track them down?
Thanks Guy's,
Bush Wacker
Thaelin
  BW:
   I was playing around with this idea, didn't know it was shuman freq. but tried to figure out how
to make a coil that would osc at that low of a frequency. House isn't big enough. I was trying to
get eight of the osc's running at the same time and wrap the output onto a torid which would
then energize the torid in a vortex fashion. Now if inside the torid, you had a motor core, well
never got to the osc part but had fun. Now it might just be a reality with the tid bits you just gave
me. Think maybe this idea could drive a poly phase ac motor? Oh my, should I even have ideas
like that?
Ha Ha Ha.
Worth a try tho. Please, comments!
Sugra
Thaelin
  Have a bit to add here. I have been looking at the video and something is puzzleing me.
The big ring is actually a torid. Inside this are two small torids. After seeing what the magnetic
flux picture looks like for a torid, wouldn't this saturate the two smaller ones so that they would
not work? Granted, they may well be leaching from the big one but I would think they would be
used to drive up the signal so it could be maybe run through a quad?
sugra
gast
Hello everybody,
I saw the videoes at http://www.harti.com/coil/ showing the Shumann resonance device.
My interest in free energy was theoretical and a bit halfhearted all the time. But this videos impressed me deeply.
This device looks so basic. A few coils and a ferrit-toroid.
My first thought was that this device act like the MEG but with self-supply, but the fact that the device stops working if you turning it upside down confused me.
Does anybody have some further informations about this device? If I google for "schumann generator" or somthing else I get much unwanted/improper results.
In one of the videos the guy say the the device vibrate about 7 Hertz. In the another video he speak from 6000 Hertz (if I don't misunderstand him). Could it be that this device contain 2 seperate tuned circuits which oscillate each on 6000 Hz but have an "parametric oscillation" about 7 HZ? That means each circuits oscillate on 6 KHz all the time, but their amplitudes are oscillating with 7 Hz up and down. The amplitude of each circuit is antipodal to the other. They swap their ampliude like 2 coupled pendulums. (difficult to explain for my, I am a little foreign language-Idiot ;-) - god safe www.leo.org)
Anyway, this device awake my interest, so I am looking for more material.
(Hope my lowly electronic stuff and the 2 digital multimeter well be enough for such a projekt)
*want to be unnamed*
