Thanks to ALL for your help!!
summary of commercial FREE energy devices
Started by ashtweth_nihilisti, February 28, 2011, 11:33:23 PM
SBK Radio
Hi Ash, it is me Carlita from Sailing Beyond Knowledge Radio, great to see you here,  ;)what is your feedback on this site http://freeenergydevices.net/magniwork Thanks Carlita
Bruce_TPU
