a question about transistors
Started by Bizzy, March 01, 2011, 08:25:07 AM
Bizzy
This is very infomrative and helpfull.
Basically I want to use a transistor to control a pulse motor. Turning on and off at certain intervals. So it sounds like a Mosfet would suit my needs better.
Bizzy
FatBird
In actuality, NPN & PNP Xistors can be turned on by MicroVolts.
For proof, look at a Transistor Radio.  The voltage on the antenna that feeds the First Stage, is typically Microvolts.
neptune
@ Fatbird . What you say is only partly true , and is likely to confuse a novice .
Microvolts from the antenna are fed into a high Q tuned circuit , to magnify the voltage . Also base bias resistors are used to "partly turn on " the transistor already , so that a small signal voltage will turn on the transistor a further amount . That is how signal amplification works .
Bizzy
Quote from: neptune on March 03, 2011, 10:58:18 AM
@ Fatbird . What you say is only partly true , and is likely to confuse a novice .Microvolts from the antenna are fed into a high Q tuned circuit , to magnify the voltage . Also base bias resistors are used to "partly turn on " the transistor already , so that a small signal voltage will turn on the transistor a further amount . That is how signal amplification works .
Yes I am confused enough...
So is that the reason why you put a resistor at the base of a transistor in a joule theif?
Bizzy
