The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
wayne49s
Quote from: casman1969 on April 07, 2011, 11:35:51 AM
Ditto on your last post. Center tap will be for my second unit but replication of the original device will be my first priority.
Glad to be in good company working on this.
Yes, it's always good to have group support for something like this.
If all you change is the center tap, soldering it on in the first unit may save you some work to test it. I doubt it will change the replication results if you don't use it initially.
/Wayne
casman1969
I was considering doing the center tap for both...
The original post says 1000' on the inner secondary and 800' on the primary. Are we still at those numbers if we use 16AWG?
Mavendex
Umm there may have been a mix up, on the innercore and outercore for this Im truly sorry, and accept responsibility for the mix up, so if you need to send bad karma my way you are fully within your rights.
I hope you can either get a exchange or find a way of producing your outershell.
It was brought to my attention that the cores didn't match up that the M-416 core would not fit in the outershell Im having made.
I took apart the transformer I had rigged up and did my own measurements and the measurements that I had Jeff take were correct and the part number I have been spouting across the board for the nanoperm is wrong.
Again Im sorry so sorry,
The Nanoperm size was the largest size that they offer not the next to largest size.
I can't believe I made this fatal mistake and I hope you all can forgive me.
Mav
Hopefully you can get it it exchanged without much problems and hopefully we didn't get 30 people buying cores.
Flame away....
e2matrix
Anyone can make a mistake but it takes fortitude to admit to it.   Now I am somewhat confused though as to which part number would be the correct one to use.  Did you mean the M-416 is too large?  If so and some have that on order I would think getting the outer shell made larger (if possible) would save some rather expensive return shipping and lost time.
  Can you clarify which part number would be the correct one or the dimensions?  I'm not currently attempting this build but may try in the future and unless I'm the only one that isn't clear on this it will help others out.
Mavendex
its M-417 200od x 175id x 30tall mm
again im truly sorry about this
