The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
0 Members and 18 Guests are viewing this topic.
wayne49s
Quote from: captainkt on April 08, 2011, 04:12:13 AM
Hi, I hardly ever post but tried Gabriel coil and followed to the letter, (the factory next door to me spins steel donuts ). I found no OU just a transformer, the toaster is probably 1kw like mine so watts in were 1350 on monitor  bulbs on secondary 350W and second monitor reads 347. I was well disapointed .
Keith
@captainkt
From the picture, it doesn't look like it's large enough to contain the same inner core, which is about 8" diameter. What is the type and size of the inner core you are using?
/Wayne
friendenergy
Hmm, I see Capt Steel Toroid but I don't see any wires? I take it this is a before photo you took before you built it in 4 hours?
captainkt
Hi,
5 inch inner core from ferrite toroid transformer, I can get a larger donut (up to18inch)  if you think a larger size might work. It would certainly be easier to wind with larger diameter centre hole.
regards
Keith
wayne49s
Quote from: captainkt on April 12, 2011, 04:34:11 AM
Hi,
regards
Keith
The point is that it is not an exact duplicate of the original device, so you don't really know what are the changes that caused it to give different results. For example, Mav mentioned that an iron powder variation did not work. That's why the quickest way to validate is often to validate with exactly the same parameters as the original to get your own working reference from which you can experiment, rather than to use the parts you have available. Once the parameters are changed, and it doesn't work, you end up with the situation where you do not have a sure way to make it work other than to remake the device exactly. Double the work with half the confidence.
/Wayne
captainkt
Fair comment, over the last few years I have made dozens of builds,nearly all Kapanadze type and just seen effects mostly with exploding equipment, perhaps this time I should take your advice.
/Keith
