The Gabriel Device, possible COP=8
Started by Feynman, March 22, 2011, 04:07:09 PM
matthewklinko
Quote from: Mavendex on October 21, 2011, 09:01:36 AM
Im back but busy catching up on work, I meet with investors on Monday, after which I do a little show for them and we talk about where we should get started.
Have you added more than 400 turns of primary?
Have you changed your input method?
Have you messed with the secondary?
Have you added shorted turns to your secondary?
If I were having problems those things probably would be where I would get started.
Hello mav , that's good to hear .it would be good if you found sometime to take a short video and explain your setups and show them working
It would really help us understand and preceded quicker
I have just tried connecting my setup to 110v ac from the wall.
I have 400 turns on primary and it seems not enough current flies up and saturates the core.
I put a 60w globe in series to limit current and voltage across coil becomes like 5v not enough, and current is always in phase with voltage .
I haven't done any shorted turns as I want to get first stage of power factor zero
And secondary is still the same at 2000 turns
Can you see anything in doing wrong ?
Mavendex
Quote from: matthewklinko on October 21, 2011, 12:06:20 PM
Ya that would be nice, too bad time is of high value and of low availability, I think there is something in the downloads section provided by Schubert with his setup that would probably help you.
60w globe = not enough juice try using something more robust, with 400 turns that 60 watt globe probably won't draw the .5 amps at which point won't charge your field.
If your going direct from the wall and not getting a reduction in power factor I would think mabye that you should try a different meter 400 turns over 2000 turns should get you at least 30% pf if not more.
I always hook my meter directly to the wall this way I can get the losses calculated from the variac in place plus the voltage from the wall will power the meter vs placing the meter on the variac. My meters will read PF Watts Amps Volts and are very reliable at 120 volts. After I use that just to make sure the measuerments are correct I use a Fluke amp clamp. 99% of the time its dead on acurate.
I am using a variac this helps tremendously.
So you haven't tried a 1 to 1 ratio? Alot of people are in that range and have gotten good success rates.
more experimentation leads to better results :)
Hope
Are you saying your turns are a one to one ratio on the Primary and Secondary or the weight of the wire is the same?  AND what gauges on each please?
Anyone else having success at 1:1 ratio please post your results for us and a parts list so I may place it in the downloads section.
ALSO there are now at least 8 other people with successful builds on here and energetic forum on the Karpanze device.
The schematics WORK now and a lot of helpful discussion about the SELF RUNNING model is there for the downloading.  Congratulations to you all.  Wishing Tariel a speedy recovery!
Glad your back safe from your holidays Mav.  Good to hear about your planning, hope you get a business lawyer to assist you that you feel is trustworthy.  It will keep you from hopefully getting the shaft like Tesla did.
Cheap4All
@Mav. Great to hear you have investors wanting to maybe checkout your invention with the hope of turning it into something bigger (for you). Here's wishing you all the best of luck in that regard. Its great to see someone starting with just an inkling of an idea and turning that into something far greater. Hope all goes with your visitors on Monday.
Mavendex
Quote from: Cheap4All on October 22, 2011, 06:37:01 AM
If I can get it my way we will just make a not for profit company this way its good for everyone :)
Thanks things should be good to go I can preform all the effects that I have described with designs on making it smaller and more powerfull with some equipment and proper instruments.
