SchubertReijiMaigo
I don't know this Tesla patent, Tesla was a great genius after all, I think the most device we try to reproduce or developing was already patented... We rediscover the work of Tesla but invent nothing finally... This guy is not human LOL...
Feynman
Okay, first , wow@the tesla patent.  Did this guy leave anything left to invent?   No wonder he got so much accomplished, he didn't have a gf breathing down his neck .
Allright, so I like the idea of running the Gabriel device off a cheap 12V inverter from a battery.  This makes it really easy to measure the consumed power (just measure the current draw to the inverter).  It's WAY easier to measure power on a straight DC signal from a battery than it is to measure a Wall AC signal through a resistive and inductive load, because of Voltage/Current phase issues.   So I like the inverter idea.
Hopefully my Nanoperm parts will ship this week.  Whether or not this particular device (Gabriel device) works as it appears (we need more tests),  Nanoperm is a really promising material for overunity research.  It has much higher magnetic permeability than ferrite.
Regardless of what happens here, I will be using the Nanoperm for Boyce TPU replication and possibly for testing EMDevices' magnetic saturation theory he has posted on overunityresearch.com.   And anything else I can think of or that seems promising.  The goal is open-source solid-state overunity.
Working on an electromagnet and my blog today, hopefully we can determine with some certainty what is going on with the Gabriel device over the next couple of weeks.
Cheers,
Feynman
Montec
Hello all
There is a way to measure mutual inductance between two coils if you have access to an induction meter.
First you measure the total inductance of the coils hooked up in series with the winding direction being the same. (L1) Series aiding.
Then you reverse one coil hookup so that you have apposing winding directions in series. (L2) Series apposing.
The mutual inductance between the coils is M = (L1 - L2)/4
Now if there is a difference in M when you change which coil is first in the series, primary or secondary, then you have something of a magnetic diode which will limit back emf.
the_big_m_in_ok
Quote from: teslaalset on March 27, 2011, 09:03:02 AM
I second that.
If Tesla's patent nr. 433702 does apply here, here's the text from the patent that hints to this.
In the Figure:
A = iron core
B = secondary winding
C = iron shielding
D = primary winding
@all
Because this was a cross section drawing, I'll assume the "iron core" is a toroid?  Did Tesla ever use toroids or is it actually a toroid?
--Lee
