SkyWatcher123
Hi TEKTRON, Don't remember exactly, though it was either hobby lobby or michaels crafts if you have one of those stores by you.
Most craft stores should have the floral steel enameled wire.
Here's a link from hobby lobby
http://shop.hobbylobby.com/search/default.aspx?searchTerm=floral+wire
peace love light
Tyson ;)
SkyWatcher123
Hi importfanatik, must have been typing when you guys posted.
It's green enameled steel floral wire and the ends are left open so no current should flow through it, just acting as the primary shell. It shouldn't matter how the ferromagnetic material is placed, as long as it has the right properties i suppose.
Hi magluvin, thanks for comments, only way to know if it will work is give it a go. I'm going to wind one layer for primary and I'm wondering if using a 555 timer to pulse the primary might work.
Otherwise, I will use a transformer output of 12 volts or so AC and see what happens.
Though i do have a 700 watt 12 volt inverter, though that might be too much voltage for this primary. We'll see.
peace love light
Tyson :)
Magluvin
Hey Sky
That was my thoughts exactly on how to approach an input to start with.
First i was thinking just a small 1A 12v wall supply, ac of course. =]
And the 555 will be interesting as we wont be sure of a freq that the transformer will be comfortable with.
And yes, we wont know till you try.    =]
Wishing very good luck for you. I applaud the trying something different than the shells, as your way, teslas way, is more viable for builders.  ;]
Im taking some different approaches also. As many are going with the shells, we can wait for them to test that way while we take steps forward into the known/unknown.  ;]
Either way, it all seems too logical not to work as described.
Mags
TEKTRON
Quote from: SkyWatcher123 on March 28, 2011, 11:34:35 PM
peace love light
Tyson :)
Thanks for the source... I am thinking the ends of the iron wire may need to be shorted together to complete the magnetic circuit?
SkyWatcher123
Hi TEKTRON, connecting the steel wire ends is not needed, think of it like Bedinis welding rod cores, that's its only function.
If you did connect the ends, whatever voltage is induced in the steel wire would create a current, which hinders its function, unless eddy currents are needed for this device to operate, I doubt it. As magluvin pointed out, Tesla used ferromagnetic wire also in his patent.
peace love light
Tyson :)
