the_big_m_in_ok
Quote from: the_big_m_in_ok on August 03, 2011, 01:16:19 PM
@Mags
Did Tesla patent anything like that?  Wait.  He did have something that had a coil inside a toroid, I think.  At the very least, there are a few patents like the .PDF that was posted.
--Lee
As I said, he had a coil inside a toroid, thusly:  #433,702.  GOOGLE's "Advanced Patent Search"   and   http://www.pat2pdf.org   should allow you to download a copy if your computer has a .PDF compiler on its hard drive.
(This computer is filtered against copying text to the address bar at the top of the page.)
--Lee
JouleSeeker
Quote from: Magluvin on August 03, 2011, 10:34:52 PM
Hey JS
Here is a link to the pat.
http://www.teslauniverse.com/nikola-tesla-patents-433,702-electrical-transformer
Here is an excerpt ...
1.A A is the main core of the transformer, composed of a ring of soft annealed and insulated or oxidized iron wire.
2.  Upon this core is wound the secondary circuit or coil B B.
3. This latter is then covered with a layer or layers of annealed and insulated iron wires C C, wound in a direction at right angles to said secondary coil.
4.  Over the whole is then wound the primary coil or wire D D. [snip]
Mags
Very interesting Mags, and I agree this is very much like the Gabriel design.
I find it clever to use IRON WIRE to form the toroidal core -- and also, to form the outside "donut" shell.
I had an idea -- to pass a CURRENT (could be AC) through the IRON-wire core and shell, in order to VARY the magnetic properties of these (permeability, etc.) in REAL time.
[/b]  Does Tesla mention such a possibility?
Anyway, I will definitely be reading the Tesla patent.
Thanks again,
Steven J
Mavendex
they make permalloy wire probably cheaper than sheets, mmmm take teslas idea and motivate it thru the 21st century don't use steel or iron to make the field but a better magnetic conductor.
Just a thought
Mav
Quote from: Mavendex on August 05, 2011, 03:40:21 AM
Just a thought
Mav
That's actually a very interesting point. Just a simple search on alibaba gave numerous suppliers; http://tiny.cc/dj3j3
That would need no machining or much hard work to spin it around the secondary or some plastic shell covering the secondary.
teslaalset
Quote from: broli on August 05, 2011, 04:32:28 AM
Hi Broli,
Found another link you might be interested in that also mentions permalloy sheet:
http://www.espimetals.com/index.php/online-catalog/831-permalloy
I tried simulating the original Gabriel device in Ansys Maxwell, but it appears that too much input power is required to get the outer shell saturated in case of pure iron.
The example shells are simply too thick to work out a practical implementation.
Iron sheet would help out as well probably and is a bit cheaper than any permalloy material I guess.
