Mavendex
how thick is your shell? what size is the device? Did you isolate your shell halves? if you add more primary the power factor goes down.
matthewklinko
Quote from: Mavendex on September 29, 2011, 08:55:40 AM
Hello Mav I think its 2mm thick its a standard 3" mild steel donut.
My core is 122.9mm x 182.9mm x 30mm
2000 turns secondary 18 gauge
3" shell
200 turn primary 18 gauge
I have isolated my two shell halves.
I tried winding another 75 turns in the primary, and the secondary voltage increase hence power as well. No change to power factor.
Please see the attached photos the secondary is loaded with a 150 ohm resister. The voltage scale is 10V/div.
Red is primary voltage , yellow is secondary voltage, green is the two multiplied.
I found that the primary current is the same phase as the secondary voltage, so hence we can use green to measure power factor.
thanks for any information and help
Matthew
Mavendex
how many amps are you putting in to the device, Ive been using a variac.
Usually all I have to do is increase primary windings to lower the powerfactor, so not sure why your having a issue with it, my shells are also a bit thicker   so that may be a issue as well.
Nice to see that the sinewave doesn't change which is nice:)
Hope
Mav will you please post some specific results of your endeavors.  If you have a video to post on YouTube so much the better.  I am near done with a large service project (my aching back, lol) and will be on this project more soon.  If we can see your out comes then we can avoid the pitfalls and more ahead as a group.   Thank you.
Mavendex
Quote from: Hope on September 30, 2011, 11:24:48 AM
I cycle thru them so quickly there is no one way to do it to make energy the simple fact that its possible should be enough, Currently I'm using intermediate or primary drivers to x out the reflections, shells drive down the power factor along with primary windings and multiple cores increase power out. (sort of)
My current configuration is 2k windings on the secondary, 100 turns of primary driver IE shorted primary winding, then shell then primary input windings, I am using 2 nanoperms and 1 set of shell to make it happen.
My next configuration will be 2k windings on the secondary single core 100 turns of primary driver then shell then as many windings as it takes to take to get it to 120, after that if everything goes well which it should I will move to 100 single turns of primary driver to see if that increases output voltage.
after that I intend to employ capacitors and a magnetic diode configuration.
What you should take from this is that the laws of physics are easily shattered and experimentation not AI is the way of the rule.
The laws of Physics are Gods laws not ours to think or act like we know all of them or how they all work is in fact a arrogance that needs to be rectified for our race to forward itself, if the armchair scientists or scientists in general can't get beyond this I fear that no matter what happens our species will fail. Learn to experiment!
As your great Tesla has said in the past.
