matthewklinko
Hello I did some tests, and rewound my secondary and placed two loops of 15 shorted turns on top.
Then i wound a 200 turn primary.
I did the following tests I input 2A into the primary the core saturates then I loaded the secondary with a 60W globe, current drops a little bit, core is still saturated, current will drop to the point the core is no longer saturated then will rise again.
I then increased the input current will loaded to show it saturates more.
PF increases as you load the secondary.
Shorted turns only increase the current and don't stop reflections.
The results I'm getting don't show anything out of the normal or overunity.
see below for photos
Magluvin
Awesome work Mat!  ;]
Now thats a Show.  Even if no ou.  ;
The scope shots, are they V A of sec? Or in and out?
Is the input just sine?  I see the wave steps. This is what I imagined. When the primary saturates the shell, then breaks through to the sec.
Thanks for sharing and showing. Good man.  ;]
Mags
matthewklinko
Quote from: Magluvin on November 09, 2011, 08:59:00 PM
Mags
Thanks Mags
The scope shots are Volts(red) and Amps(yellow) both are input, and the input is just a sine wave through a variac.
The current is read from a current transformer through a resistor.
I was thinking that it would be the secondary core that's saturating, and the shell doesn't seem to have any effect...
