SMOT - Close to closing the loop ,second video-BIG improvement
Started by billmehess, March 31, 2011, 01:05:30 AM
Poit
Quote from: gravityblock on May 11, 2011, 02:26:52 AM
Both paths start at the same height and end at the same height, so gravity doesn't provide either path with an extra advantage (The net fall is the same for both balls).  All that exists is the impulse that is applied to the body in space and imparts momentum to it. The body's movement is then only limited by the resistance it has to overcome.
GB
I agree that both start and end at the same point.. but one of them DIPS lower (during its voyage up and down)... its this dip that gives it, its extra momentum
gravityblock
Quote from: Poit on May 11, 2011, 02:32:05 AM
The one that dips lower doesn't always have the most momentum or advantage, as can be seen in this video, http://www.youtube.com/watch?v=H2QPMO6bo4E
In the below image found in the above video, the path which dips the lowest doesn't win.  The middle path wins.  It is the product of the force and the time for which it is applied that is important (the impulse) .
GB
Poit
Quote from: gravityblock on May 11, 2011, 03:01:34 AM
GB
ok... agreed :)
