0 Members and 16 Guests are viewing this topic.
polln8r
Quote from: Red_Sunset on September 09, 2012, 02:52:31 AM
If you carry on this way, you will be building, discovering something totally new, that could be better than the Zed, quite possible.
Concept Twist:
Bessler Wheel using little ZedS that reset themselves as they rotate around; using the Travis effect to shift the masses. You'd have to have pairs of them at each point, or perhaps some sort of two-way double-Zed.
polln8r
Red_Sunset
Quote from: polln8r on September 09, 2012, 03:47:04 AM
Concept Twist:
polln8r
You bet, the fat lady hasn't sang yet on this ZED concept, no matter what has been said to the contrary.
The doors are still wide open, the Grand Opera is to begin......
Michel
ionizer
The fat lady didn't sing in 130+ pages i wonder if she can sing at all.
Red_Sunset
Quote from: ionizer on September 09, 2012, 04:35:09 AM
I wonder too, It looks you are confused who is going to be the singer here on this forum.
She came on stage but she was booo...oo off the stage.  She is now only pointing you in the direction of the song.
If you like to the hear the song, you better start singing.
She has booked a new venue for her performance, singing she will, do not doubt it
Today, after more than 2 months, I had again a look at Wayne's early disclosures in this forum. I was so surprised to the details released and surprised that it took me that long at the time to see his point. He was to my surprise more than clear in conveying the working and principle of the Zed. The full solution description is there, go back and extract all Wayne's posts (only his) and read them sequentially. Time clarifies your mind.
Michel
neptune
@TK. REMOVAL OF THE LOAD.
As you know I am not the worlds greatest mathematician, but sometimes I do have a sort of intuitive grasp of concepts, and the ability to explain it to others. I have talked about this before.
  Imagine I show you a black box overunity machine. During a complete cycle it lifts a load weight 1 inch, and then lowers it back down again. To me it would seem that all I have done is given that load weight additional potential energy, and then wasted or extracted that potential energy. Net output = zero.
Now I show you a different machine. It also lifts a weight 1 inch. The weight is then moved sideways at low or zero cost, and the platform descends to its start point. Then I roll another weight sideways onto the platform. So after a number of cycles we have lifted a number of weights onto a shelf that is 1 inch higher than the "Weight storage shelf." Work has obviously been done.
In Wayne`s machine, the Zeds are not used to lift weights, but to compress production rams, which are hydraulic rams used as pumps. On the upstroke the Zed feels the weight of the resistance of these rams, as fluid is forced into a high pressure hydraulic accumulator.
As the Zed moves down, tthere is little if any resistance from the ram, as it sucks low pressure fluid from the reservoir to refill itself. We have effectively removed the "weight" or resistance.
Make sense to you?
