Free energy from zinc.
Started by stevensrd1, April 21, 2011, 05:58:01 PM
FatBird
@ Stevensrd1
The schematic shown was just a concept,,I have not tried it
WHAT'S GOING ON HERE?  In your first post at the very top, you say you did try it & it puts out 2V at 200 to 300 mA.
Now you are saying you didn't try it yet.  Are you just playing around here or what?
Which is it?
stevensrd1
If you read the print under the schematic and on my youtube video page describing this it explains it,,best wishes..
friendenergy
where did you see 200 or 300 ma? All I saw was his meter was on DCV 2 and had a reading of 200 and 300. 200 or 300 what I don't know..maybe mv so it should have been .200 or .300? Could you clear this up please. Thanks.
Tito L. Oracion
hi everyone,  good day to all of you :)
using the setup above i tried made use of my roof top and my roof top is made up of galvanize iron.
its great!  :)
pese
Quote from: stevensrd1 on April 21, 2011, 05:58:01 PM
I took a carbon zinc battery, removed everything in the battery and kept the zinc can. The can was washed, boiled and dried. NO remains of the acid or carbon or tar or anything left in the can. Just a clean zinc battery can. Then I took 2 diodes. Soldered one diode inside the can, to its inner side. Then the other diode was soldered to the outside of the can, and by using the polarities of the diodes I had a positive in the can and a negative outside the can. Now I connected an earth ground to the positive diode. And using my meter connected to the ends of the diodes I got a constant reading on my meter on DCV 2V setting of around 200 to 300. This varied ever slightly over the time during the day and night but always around or rather between 200 and 300,,sometimes more then 300 actually. Now this is a form of free energy in itself all tho be it a very low amount of power, but its constant and non stop. I have also found I can ever so slowly recharge a capacitor with this setup, and if I connect an antenna to can itself,,the capacitor charges faster,,but still over all slow. None the less this is constant free energy from zinc. Now I have read that zinc will give off electrons if in the presence of ultra violet light. I have also read something about a metal charged sphere,,that the electrons will migrate outward on the outside of the sphere and not remain inside or on the inner side of the sphere. I really am not sure how this setup I made is working,,but it is working. I dont think its being powered by ultra violet light,,as the capacitor will charge at night in total darkness. I dont think its really working as a charged sphere with electrons just collecting on the outside of the zinc can for more surface area. And I dont think this setup is working like a crystal radio set since the diodes used are in no way like the ones used in a crystal set, they are the bigger black diodes 1n400 types. So how is it working,,all the time,,is the zinc perhaps just pulling up electrons from the earth,,or is this perhaps a primitive form of zero energy being tapped into. Questions remain, I made a video of a possible improvement to this setup,,you can view it here, please read all written there as well to better understand. http://www.youtube.com/watch?v=AsZgyI9WsFE
Think about, that you have not "received" the "hum" from 60hz- line frequencye. (So the 1N400x diodes are fine.
BUT:
If etheric or only rf-wafes are the source of the energy....
try to use. fast swiching diodes,, schottky diodes.
OR see to find  old germanium diodes,
like 1n34 1n60.
(eventually, take it out from old AM , AM/FM transistor
radio-receivers.)
In any way, you receive more voltages.
Pese
