Build a Moray-like device
Started by Ros-Co., May 28, 2006, 06:09:32 AM
Pephyon
Excerpts from http://www.rexresearch.com/sweet/1nothing.htm (see the topic "The Overunity Electrical Machine's Secret" in Progress Report on the Sweet Vacuum Triode, T. E. Bearden)
Here's the magic secret of all electrical over-unity machines:
1) TAP THE VIRTUAL PHOTON SPRAY.
2) TAP THE ENERGY IN THE MASSLESS VACUUM POTENTIAL.
3) DO NOT RELEASE THE SPRAY PUMPS.
4) DO NOT ALLOW CURRENT FLOW IN THAT PART OF THE CIRCUIT WHERE THE CHARGE PUMPS ARE COLLECTED TO CREATE THE POTENTIAL.
5) OR AT LEAST ALLOW ONLY THE ABSOLUTE MINIMUM OF FLOW/BLEED-OFF THERE, OF THE PUMPS.
6) ORGANIZE, GATE, AND APPLY THE POTENTIAL SPRAY TO THE EXTERNAL CIRCUIT, WHERE IT WILL ATTACH TO AVAILABLE ELECTRONS, FORMING FORCE FIELDS, VOLTAGE, AND CURRENTS TO PUMP ELECTRONS AROUND THE CIRCUIT.
7) USE THOSE EXTERNALLY POWERED FIELDS AND CURRENTS TO POWER THE LOAD.
Conclusion is very elucidative too. I expect for comments.
Bruce A. Perreault
This is precisely how Moray's device works. Chech out my U.S. Patent
Application that has been recently approved...
http://www.nuenergy.org/disclosures/US-2008-0272680-A1.pdf
The claims have been updated in my granted patent which will be published
soon.
                  -Bruce A. Perreault
Pephyon
So, you utilize triode (vacuum triode amplifier) that incorporate Solids-State signal processing? You say that "spray pump" Bearden is refering to capacitor?
Also, with due respect, how you patented something wasn't invented by you? Perhaps a new circuit pattern design, isn't? Thank you.
XS-NRG
Quote from: Bruce A. Perreault on August 13, 2010, 11:08:35 AM
soon.
                  -Bruce A. Perreault
So where is your ground wire, and your aerial ?
Pephyon
Quote from: hartiberlin on July 28, 2006, 11:17:45 PM
It was also radioactive and worked as a nice
"passive amplifier" for radiowaves, when he tried this
as an diode in his earlier radio receiver experiments.
Compare with this quote
Quote from: allcanadian on January 05, 2008, 02:52:09 PM
Here are some aspects of the moray device that are usually not considered, in the picture below(upper left corner) is a basic crystal radio
