W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
Bruce_TPU
Quote from: nightlife on April 26, 2011, 09:16:59 AM
Everything about this is equal. Where and or what is unequal about this that can make it work to produce an excess amount of energy? Equals can not produce more then used.
My guess, is you take the first sentence of Bill's, from his other thread, you think of the moving base, and you think centrifugal force.  I can see it working.
Cheers,
Bruce
dllabarre
Quote from: Bruce_TPU on April 26, 2011, 09:24:11 AM
Cheers,
Bruce
Please do tell... What other thread?
DonL
DreamThinkBuild
Hi Protech,
To avoid confusion and misinterpretations can you post a photo with dimensions/weight or PM me if you don't want to post it here. I am willing to scale it up. If you want me to replicate exactly I need exact specs then there will be no question that something is off. My only interest is seeing your idea succeed, negativity is not required.
Thank you.
Bruce_TPU
nightlife
Cheers,
Bruce
Gravity has an equal pull from both directions back to center as do magnets and the movement produced will also have equal motion back and forth and the resistance is what will keep it from becoming perpetual. Even if it could be perpetual, no energy can be gained because any resistance added will stop it from being perpetual.
