W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
Bruce_TPU
Quote from: MrMag on April 27, 2011, 03:43:13 AM
Have you even read his posts. He talks like a little kid that thinks he's so smart putting everyone down. If anyone is doing mocking, it is him.
I guess that's what we are asking of him. He wants us to replicate but it would be nice to see the real thing, you know the one he built. A video of it working would also be nice. Do you just drop everything your working on to replicate a picture? Maybe sometimes but not always. Like I said, he said it works, so why not show us.
That's what we are worried about, if it's real. Are you going to build one? I don't know about others here but I'm not going to replicate something without some kind of proof that it works. If that was the case, we all would have a ton of money invested in half built OU devices that don't work.
And you don't have to mock us about being "freakin' PC hero's"
Do you remember the post you made in the other thread,
"No one will stomp on you if you have something that works.  If all you have is untested or untried theory, that would be different.  But if I read your words correctly, you have something that works, and the majority will listen."
I agree with you on this post. If he shows us a working model, which he says he has, there will be a lot of replications going on, I guarantee it.
Look, I have no proof it works, but I have no proof it doesn't.  It costs only a few dollars to build.  If nothing else anyone trying will have learned something.  For those who never experiment and never build might as well wait for the next FE product at Walmart.
Does anyone here know how many times one must fail, to succeed?
Those who build something do.  I never said it was you or your post, but the general attitude displayed in some of the posts above posts I found objectionable.
Cheers,
Bruce
nightlife
Quote from: Bruce_TPU on April 27, 2011, 04:55:07 AM
Cheers,
Bruce
Yes, success can come from failure as long as you learn from your own  failure as well as others. Learn why you failed and as long as you dont make that mistake again, you will be succeeding. I see many here making the same mistake over and over again. I have made the same and found out why I did. I have explained this so others can think about it and understand how they have failed and or how a design with the same concept will fail. Magnets and gravity have equal pulling and or pushing statationary forces. Meaning, they either pull to the center from all sides or push from the center from all sides and those forces are equal and stationary from all sides. There is no way to over come those forces without adding a flow.
protech
ok so im bACK DID YOU LEARN ANYTHING ........yes i called you guys stupid ...but hard love is going to take its course ............
protech
Quote from: nightlife on April 26, 2011, 08:59:38 PM
Bruce, I posted reasons why it wont work. I wish it would but it cant, atleast not as designed. I'm not trying to "mock" anyone, I am trying to get people to think about things before jumping into them and wasting time. My reasoning is well justified and comes from expiriementing on my own.
I am only trying to help by steering people away from ideas that wont work so that they can keep investing their time thinking of some that can. I only will steer away if I know for a fact it will not work. When I do so, I will explain why it wont work unlike a lot of others who just do so to be mean without even giving a reason why it wont work.
oh i love you..... your just what i want ................just remember guys i teaching stage 1 but I am at sAGE ...5
protech
I LOVE YOU TOO .....TOO BAD .....you do not use your brain ......if you have one ......
