W.K.Coombs Open discussion thread
Started by ramset, April 25, 2011, 05:32:07 PM
nightlife
Quote from: Bruce_TPU on April 27, 2011, 09:50:33 PM
Your drawing is not even close to what was described-  FYI
How is it not?
I am not here to play games. I do not take kindly to being personally attacked. Any real man would do that in person and if anyone wants to attack me in person, just email me and we can get together. Otherwise, you should do as I am and debate with justifyable reasoning and try not to make it personal.
Bruce_TPU
Quote from: nightlife on April 27, 2011, 10:05:55 PM
How is it not?
Please read what the man wrote in his other thread.
Cheers,
Bruce
protech
How is it not?
your a idiot I am giving away the farm and you say it can not be done... guy wake up ........what do you do in life a clerk for wallmart
ramset
Thanks Grandma
protech
GUYS do the simulation I posted like $5.00 IF YOU HAVE NO MATERIAL AT ALL AT HOME,, FEEL THE EXPERIENCE .......I did it 2 years ago.......
