Petrovoltaic Cells
Started by ibpointless2, May 02, 2011, 08:40:56 PM
ibpointless2
I took a cell that normal only outputs around 100mV and I hooked it up to a 1uF capacitor to see if it would charge it to the 100mV. After 12 hours it has charge to the 100mV and then exceeded it and it is now over 500mV. The capacitor was left shorted out for 24 hours before the test started so that rules out an excess charge from the capacitor.
It seems that the cell outputs more power over time. I would like to see a galvanic cell do this.  :D
ibpointless2
Hooking these cells up to a meter does drain them at first but it will soon find a voltage it likes and stay there for a few minutes until it starts to climb back up. The meter acts like a load, for example hook the volt meter up to a capacitor and watch it drain the capacitor til it gets to 0 volts and then stop because no more power is left in the capacitor. The glue batteries voltage will go down when a meter is hooked to them but will soon start to climb back up in voltage. I've seen this effect of the cells starting to output more voltage when given a load, no other battery can do this.
ibpointless2
I've been testing these cells much more throughly. I've had a meter connected to the cell so that I can watch it, the cell is giving a constant output of voltage. I'm testing all factors of humidity, temp, and moon phases. The results I have so far are very young and can not draw definite conclusions from them yet. So far temperature and humidity have some small affect on the cells but they're not proportional though. I can't say for definite that temp and humidity is what powers the cell because the decline or rise in voltage is not proportional to the temp or humidity.
The voltage was the highest when I first connected the cell which was at night. During the day it seem  to lost some of the voltage but I don't know if this is because of the night or day, or if the cell is going through a cycle.
ibpointless2
I turned off the electricity in my house from the breaker box to test to see if the cell still works. The cell still works and shows a constant output of 3.6mV. 3.6mV was the same amount that I was getting before the power was shut off so that show to me that i'm not merely getting electricity from the house's wiring.
One strange thing about the cell when the power in the house was cut off was that it seemed to respond to my presence. Standing 6 feet away from the cell and waving my arm jump the meter up Milli-volt. If I walk 4 feet in front of it it jumps the meter around too. To make sure I started throwing any non-living thing around but never hitting it. I threw a nickel, paper ball, pen and the cell didn't react to them. If I get a couple feet away from it then it starts reacting as if it responds to living things. It even reacts to my cats when they get near. I find this odd especially since all the power in the house is off and i'm standing 4 feet or 6 feet away. I don't know what is going on but I thought I should let others know to see if the see this effect too. I didn't see it yesterday when I started but the next day I could see it.  ???
nul-points
Quote from: ibpointless2 on May 04, 2011, 12:28:55 PM
I didn't see it yesterday [Tuesday] when I started but the next day I could see it.  ???
...must be a Wednesday kinda thing!  ;)
