SMOT - Next Video
Started by billmehess, May 03, 2011, 12:54:33 AM
billmehess
Unfortunately this is not a solution to my work,  notice that both slopes are extreme. Any kind of slope will return the ball to the entry point and that is all I am working towards.
mscoffman
Quote from: billmehess on May 13, 2011, 12:11:05 AM
What is the braioschtoire principal?
Also in my continuing work on a self looping SMOT I have found a way to have the ball propel itself
off the end of the uchannel instead of the normal dropping off. Just a thought here, since the ball enters the uchannel at a fairly low speed but shoots off the end of the uchannel at an incline it would appear logical to think that there is more energy out than in. Is this correct?
Is this correct? - Affirmative. The ball is on a ballistic trajectory modified
by any residual R^2 magnetic array attraction (in any case) but shooting
it off means there was more energy. The distance it impacts a sunken flat
plane away from the end of the ramp could be used to estimate it's momentum
energy. Further is higher... As usual, good luck.
braioschtoire principal -> The formal name given by mathematicians
to the tendency of the gravity affected spheres to have different
intermediate speeds on one track curvature vs another. The name of
the analysis that gives correct answers.
:S:MarkSCoffman
billmehess
Quote from: mscoffman on May 13, 2011, 02:02:11 PM
:S:MarkSCoffman
Thank you Mark
Is this then a definitive example and proof of OU?
hartiberlin
Hi Bill,
Greg Watson said, that you can only get the ball away from the ramp as in your case,
when it falls deeper than the entrance and then bring it up again to the entrance.
For this reason this brachistochrone principle would be great !
(sorry for me wrong spelling in my last post here...)
Good luck,
Regards, Stefan.
futuristic
I  have never seen anyone trying this setup (in the attachment).
Figure 1:
Hold magnet above the exit point of the ramp. Try to find the distance/position where magnet helps pulling the steel ball away from the rail, but at the same time the magnet should be far enough that steel ball doesn't jump and stick on it.
Figure 2:
You could also try with two magnets in attraction mode, but separated by an inch or less, which would continue the magnetic field of the smot in the air.
Happy building ;)
