Alternate Fuel for Diesel and Gasoline Engines - 100% off the Bowser
Started by ElectricGoose, May 09, 2011, 08:42:38 PM
ElectricGoose
Quote from: Johan_1955 on May 12, 2011, 11:20:35 AM
Emulsified Fuel in action: http://www.youtube.com/user/OostromTechnicsSL
Regards, Johan
Great post Johan!  Thanks for your input.
40% and 50% saving from emulsified fuel people.  Thats what its all about.  Those Diesels arent fussy.
evolvingape
Hello Everyone,
I have started to look at possible methods for Kelly Kettle conversions to Gasification Reactors and the news is good :)
I have put up some diagrams of some of the directions you can go with these conversions.
The steam chamber that is built into the wall of the Kettle is a bonus, but just be careful to take all necessary safety precautions, like pressure relief valves and gauges etc before you seal it or it might EXPLODE. You have been warned!
RM :)
evolvingape
Hi Everyone,
I was shopping in ASDA today and picked up one of these:
http://direct.asda.com/ASDA-Potato-Ricer/001420063,default,pd.html
It has dimensions of 102mm wide and 69mm deep and fits the interior of the Kelly Kettle perfectly.
With the fire base inverted a very good seal is formed as the kettle is designed to be stored like this. The seal was so good after being stored like that it was really hard to separate from the Kettle.
You also get a very handy handle that I will be using to shake the basket. I was thinking of spring loading the handle in the up position to keep the basket jammed up against the chimney taper.
Rig up some threaded rod to connect the handle and basket and that should do the trick nicely :)
I am now well on my way to my first downdraft mini gasifier  ;D
RM :)
