Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
Hoppy
nul-points
Quote from: Hoppy on June 15, 2011, 08:52:50 AM
Its to heavy to get it up there! -  ;)
at my age there's no shortage of reasons  to be unable to 'get it up' there...
thinking about it, 'shortage' is probably the main reason!
Hoppy
Quote from: nul-points on June 15, 2011, 09:27:56 AM
LOL: I'll drink to that!!
hartiberlin
Hi Fausto,
well done !
So with no DC path in the output, only AC coupling you get
no Lenz law drag down effect ?
How much power can you extract this way on one coil pair at about 920 RPM ?
Many thanks for your great work !
Regards, Stefan.
hartiberlin
Hi Fausto and all:
I wonder, what will happen, if you use no DC path in your output,
but only use 2 Avramenko plugs to generate the output DC.
So put on every coil output wire just an Avramenko plug with 2 diodes and 1 cap,
so for each coil you get 2 Avramenko plugs.
Then you have no DC current path.
Would be optimal also with coil shorting cause there you have fast changing waveforms...
and it would also not slow down the rotor.
Regards, Stefan.
