Muller Dynamo for experimentalists
Started by plengo, May 12, 2011, 01:04:21 AM
wings
Quote from: wings on May 20, 2011, 08:07:52 AM
my experience is much less than yours, just a reading hobby with small experiments.
I read a document in the past by Cyril Smith that speculated about OU from a cycle by BH magnetization.
now no longer found in internet and I have only one copy on paper and I will find it.
thought: in this case the ferrite core domains are aligned in some direction, direction changes do not start from random arrangements that involving more flipping energy ....
in any case more in: phase i.e. more rapid, more powerful
Energia Celeste have the pulse delay coils installed within the magnet!!
Kunel also ?
relating to magnetic domain alignement by external magnets
here two experiments that explain the effect of stator magnets effect on coils during
motor configuration = magnetLauncher
generator configuration = solidStateGenerator
in the generator phase the you have to assume the equivalent effect (in reality you move by rotation the small magnet and so you recover by the coil the energy)
http://science.net84.net/magnetic-generators/generatorY.html
LtBolo
Fausto may smite us all for the theoretical discussion, but...
Assuming that magnetic viscosity delays the propagation but does not eliminate the energy, even 10us might be useful at a high enough rotation speed. The rotor magnet approaching the coil will induce an opposing field in the coil, and as it crosses over the center-line of the magnet, that will reverse into an attracting field. Both will produce drag equal to the power induced. However, if the repulsive field stays around long enough to start pushing the rotor magnet past the coil, that cancels some of the drag coming in. The longer that reversal is delayed, the more that you will have current in the coil that isn't producing a net drag.
Even 10us delay at the speeds that RomeroUK is running might produce a significant bias. I did a quick estimate, and it looks like 10us could shift the effective reversal by a couple of mm. Additionally, the diode bridge will chop the current as it pulls back from the high point, which may further delay the ferrite's ability to reverse the field...since it will also delay the establishment of the reversed field...it takes energy to remove the existing magnetic field. It would stand to reason that a high coercivity material will delay both the onset of the repulsive field and the reversal of it into an attractive field.
Just thinking out loud.
khabe
hi LtBolo,
Have you thought about that very long time and very many peoples have been messed with PM motors and generators, some of are very smart, some bit less ... Why none expert in detected such kind phenomenon you are talking about ???
Im not belittling you, not talk down - Im just asking - perhaps you are right,
How about to know what is your experience about this area?
Or you just read something like that from somewhere ::)
cheers,
khabe
plengo
Quote from: LtBolo on May 20, 2011, 05:12:13 PM
Cool. It is progress what you are doing. The problem is non sense discussions, ranting and so on.
Good talk.
Fausto
LtBolo
 @Khabe
Magnetic viscosity is a well established phenomenon.
The idea of the phase delay due to it is my own idea, but I am sure that others have considered it as well. I didn't think it was viable since I was expecting it to be a nanosecond delay...not microseconds. At microseconds and 100s or 1000s of Hz, it could make a very significant change to the integrated drag force.
It is also interesting that the thing that makes this work as a generator would be seen as losses in a motor. The very reason that pulse motors can approach 100% efficiency is due to the ability to tighly control pulse phase and duration, thus eliminating those losses.
As for all of the smart people that haven't seen this...well...how many overunity devices have you seen? I'm just suggesting reasons why RomeroUK's device worked...not trying to explain the 99% failures.
