Kacher - Avramenko single wire transmission
Started by Magnethos, May 12, 2011, 03:42:36 PM
Magnethos
I have seen some information about the "Single Wire energy transmission" of power. I'm interested in discussing here how this technique exactly works.
I'm not very expert in electronics, so I hope someone can explain better how it can be accomplished.
yssuraxu_697
Hi, I always try to think of electricity like it is water, or maybe even superfluid or gas. Then it all suddenly starts to make sense.
In this case:
Take 2 rubber balls, connect them with hose. When you squeeze one ball other inflates and if you let go other deflates. In the hose you got Alternating Current (AC) movement of fluid or gas. This is how simplest single hose transmission works :P
Add some one-way valves and there's Avramenko.
worldcup
hi,
I just thought to bump this old thread with interesting experiment -
The Avramenko plug and one wire power transmission
https://www.youtube.com/watch?v=XE5cka9ddFs
forest
If you build it you must check it with original Avramenko proof of concept by cutting the single input wire and making a knot without copper connection anymore. I checked it and it works like that !
