mag-gravity
Started by FreeEnergy, May 30, 2006, 03:50:44 AM
gyulasun
Yes, ok but the main question is just the decrease of the flux to SOME extent,  i.e. to an extent which is just enough to overcome the sticky spot at the top position. You would need diamagnetic material like bismuth or pyrolytic graphite sheets which are highly diamagnetic.
Found a link on bismuth: http://home.earthlink.net/~lenyr/levmag.htm and it seems to be formed easily at home to a flat sheet format too due to its low melting temperature point.
Also a good info on diamagnetic materials is here:
http://www.physics.ucla.edu/marty/diamag/ajp601.pdf        and also here:
http://www.physics.ucla.edu/marty/diamag/diajap00.pdf
The "latest" strongly diamagnetic material is pyrolytic graphite and it is available just in the correct shape for your arm:
http://sci-toys.com/scitoys/scitoys/magnets/pyrolytic_graphite.html
Now your idea can be tested! Go ahead!
rgds
Gyula
FreeEnergy
FreeEnergy
also when the arm flaps close there is kinetic energy that can be preserved in a circuit that can also help in turning off the magnetic field or at least decrease to some level. we would have to have seperate blocks of magnets in this case, have the last bigger magnet block turn off/on its field.
