PhysicsProf Steven E. Jones circuit shows 8x overunity ?
Started by JouleSeeker, May 19, 2011, 11:21:55 PM
NickZ
   NP and All:
   Although I agree with most of what you have mentioned, I must say that there are some anomalies in these BwJt or Hartley Oscillator circuits. The ultimate anomaly is that the source battery is being recharged with every pulse, as I mentioned.  Most circuits are not efficient enough to keep up with that low or tiny incoming source of energy, and will run down and discharge the battery.  But, every once in a while, like with Koolers 5 month running BwJt circuits (two) as an example,  the circuits did last, until the non-rechargeable batteries leaked from constant self charging.  The pulses are going back to the battery, I believe that can be confirmed.
  Maybe now that Kooler is posting again, he can answer some questions about his long running, almost perpetual circuits, himself.  As his leds were still very bright, after 5 months of use.  I have not been able to replicate those results myself,  yet...  Now he is using the 50.000 to 80.000 nano(perm) toroids, on his newest circuits.
  Dr. Stiffler came up with another example of light out of thin air, with his three coils, no transistor, or any battery source set up, lighting an led or two.
nul-points
Nick
the type of circuit used is not critical - it doesn't need to be a Hartley-type oscillator or any type of JT
i have one system which has now been running continuously since mid-Feb and self-sustaining for more than 5 months - it uses a 'relaxation' type oscillator: the cell charges a capacitor and, when the voltage reaches the trigger level, an SCR type circuit triggers the switching transistor to discharge energy from the cap and pulse it thro' an LED. The cell then recharges the cap and the process repeats
the Stiffler 3-coil circuit is unshielded and has an Earth connection - a good scheme to harvest any stray emissions in the area or from the Utility lines
the systems i'm reporting are all shielded and have no earth connection - essentially each one is inside its own Faraday cage - no pickup of stray signals
of course it would be interesting to hear more detail from Kooler about any of his circuits, but in this case since one of my circuits has already been running for 6 months, without nanoperm cores, and the simple DIY cells are still in good condition then maybe i can give some tips to him!  ;)
good luck with your replications
np
http://docsfreelunch.blogspot.com
NickZ
   NP:
   Dr. Stiffler has mentioned that what is being pick-up are not stray radio, Tv, or grid signals.
   I'm not sure I follow your circuit with a blinking led. Do you have a video or circuit of it? A source battery is charging a cap that discharges through an led?  But the battery is not dropping, is that correct?  Can it maintain a useful steady bright led light without the battery dropping in charge?
kooler
Quote from: nul-points on August 22, 2011, 11:09:31 PM
i would love to see your scr working your transistor.. and please show me what your triggering the scr with at such low volts.. without sticking open and draining the whole device.. i have 30 or so different volt triggers from 2-5 volts which cost me 5 ua in a circuit and then the scr cost me 100ua.. ??
oh lets see how bright your 6 month circuit is ..  ::)
i can make a dull led lite ..probably till i die.. sooner than you think..  :D
but really..  teach me something.. i am always open to learning
theres so many phd's is these forums in the last 2 years.. you would think we would have atleast a 500 kw unit by now..
show me something really kool and i will give you my two transformer device..
oh.. i like your nice line charts.. keep up your good work..
i may not be back for comments till thursday or friday.. so if you want to flame me wait till then .. thanks
robbie
Hope
Ok to gain some BEMF and turn it into real power we need to watch and understand this link instead of asking Steven to teach us.
http://peswiki.com/index.php/Directory:Perepiteia_Generator_by_Potential_Difference_Inc
This is one of the things big brother didn't want us to know.
