Claimed COP of more then 1,000,000 (million)
Started by Bruce_TPU, June 01, 2011, 10:02:17 PM
ElectricGoose
Quote from: Bruce_TPU on June 01, 2011, 10:02:17 PM
Have any of you heard of this man or his work?  He is a fellow Texan (from Texas, USA) and seems to have made the powers that be, very upset...
http://www.zeroamptech.com/on.html
Claims he can now power 8,500 homes.  Something about a special "drive" ??
The story in his own words:
http://www.commutefaster.com/audio/sumaruck-cmpr.mp3
PESN Rebuttal from 3 years ago:
http://pesn.com/2008/11/30/9501504_ZeroAmpTech-demo/
Cheers,
Bruce
OMG, Gullible much??
Even without knowing a single thing else, IF the man had even 1/100th on his way to "a million times OU" with his silly black box, ask yourself what need would he have for the genset or those big banks of batteries??
You read all the articles and all it comes across as is a gun toting, daft Texan, ranting on an on about himself and how 'the man' is against him but nonbody better mess with his navy Seal buds!!  Oh dear.
1)  He didn't even hook the amp meter up correctly (and wouldnt allow it to be done so)
2)  Wouldnt allow a scope to be put on the box.
3)  Wouldnt permit the electric motors to be loaded.
....the list goes on....
PESN looked at it and they stated (among many other things) -
"Probably Not Overunity
The ensuing discussion in the NEC forum was fascinating, as several people who have had extensive exposure to systems similar to this one raised questions and pointed out factors that need to be weighed in drawing any conclusions about what had been seen. Several people concluded in those discussions that the demonstration we saw is not definitively overunity.
Some of the reasons given are as follows:
Pete was not running the amp meter in series on the input, but in parallel; so the 0.241 milliamp reading was not accurate, but was low by a large factor.  An undetermined amount of the input electricity was flowing through the telephone wire, while some (0.241 milliamps) was flowing through the meter.  Jim Dunn tried to get Pete to run the meter in series so that all the electricity would flow through the meter for a more accurate reading of input current, but Pete never did that while we were there.
One of Pete's 2-HP motors.
The motors were not running at full speed per their name plate rating.
The motors were not starting up rapidly.  I timed them going to full speed between 2-4 seconds -- a "soft start".  Under normal operation, they would start up in less than a second, and could flip on their side if they were not mounted.  None of Pete's motors were mounted.
It would take around 2-4 amps to soft start the five motors with no load on them.
Pete's telephone wire junction where the amp meter was placed for parallel amp measurement.  Same as "A" in above photo.  A single strand of this multiple-strand wire would be larger than 60 gauge, which would be barely visible.
Telephone wire nowadays is typically 24 gauge (ref.), which is 0.0201 of an inch in diameter (ref.).  Jim said 24-gauge wire can carry 10-20 amps before it melts.  He uses it as a "poor man's fuse" for some applications.  It could easily carry the 2-4 amps that it would take to soft start up the five motors.  When I asked Pete about this later, he said that the telephone wire was of much smaller gauge than that -- like 60 gauge .  Jim said that telephone wire would never be less than 26 gauge.
When I had an RPM gauge held tight to one of the motor shafts to time the interval between start-up and max speed, the telephone wire burned up when Pete went to start it up.  Apparently, that much load was enough to overload the input wire.  Pete had to replace it with something a little thicker (~22 gauge).
The output to the motors may have been a pulsed width square wave, which will give an artificially high amp reading using a clamp-on meter as we were doing. "
Clear to me the guy is full of crap.  I guarantee his house is still on the grid....and with 1,000,000 OU oh my!!!! LMAO
Bruce_TPU
OMG (to quote you) as usual you don't listen.  You assumed. I said NOTHING of an opinion on the tech.  Just curious what people here had heard about it.  A friend sent me a link to his website yesterday.
Cheers,
Bruce
P.s...I posted the link to what you quoted fyi...if you had read anything e goose!  If your listening skills were as large as your ego, youd be in good shape.  (wink!)
sm0ky2
from what i understand, these are products similar to what he claims to be "modifying". - keep in mind, during his original discovery, the "modification" was performed ACCIDENTLY!!! during a repair..
so there must not be much to this....
http://www.bardac.com/pages/products/ac_optidrive-i55.html
http://www.variablefrequencydrives.net/wegcfw-10plusvariablefrequencydrives.htm
Bruce_TPU
Quote from: sm0ky2 on June 02, 2011, 11:45:30 AM
Hi Smoky,
Thank you very much.  I did not think that this was the kind of drive he was speaking about.
I found some good reading off of a link from a link you posted:
http://www.variablefrequencydrives.net/variablefrequencydrivebasics.htm
This explains why the "soft start" on the motor, that was a concern to PESN.  It is actually part of his tech.  It would appear that perhaps he has produces his own software that will act as a variable frequency drive for the motor, and I already can guess the means of "gain".  "Harmonic Distortion".  And the power source of that is the Schumann's Resonance and it's EM waves.  I would guess, that on the original "drive", he REMOVED the isolation transformer, and "promoted" harmonic distortion.  So, with a "homemade, programmed variable frequency drive, you decrease the energy and wear and tear on the motor, and then decrease more the input via harmonic distortion.   Match the output to the load, thus his "resonance" statement.  Interesting...
This page would explain the "flywheel" in the setup and it's reason, perhaps:
http://www.variablefrequencydrives.net/acvariablefrequencydrives.htm
Very interesting.
Cheers,
Bruce
e2matrix
As I stated in the other thread : "He never claimed he was a Navy seal.  Get your facts straight.  He said he worked as a private contractor for the Seals.  He has eagle like vision and can shoot the legs off a flea at a thousand feet ... with no scope. "
I've read everything possible on him and his tech.  Sterling and Dr. Steven Greer both tried to buy it from him.  He initially went with signing an agreement with Greer (UFO CSETI head honcho who says energy supression is related to UFO supression).  But Greer was never able to come up with enough funding and the contract was basically nul.  Sterling was peeved about that according to Pete.  I had email with Pete.  I honestly don't know if he has something or not but he is not currently trying to sell anything.  I was asking about purchasing plans or DVD on how to build as he said he was going to offer courses that would give you blueprints with all details on how to build.  He seems to have interest in getting it into the hands of the people and not some corporate interest that will bury it or make it only for the rich or military.  My point is he did not ask for one penny from me or try to sell me anything even when I was asking and offering to buy something (although I was not yet set on going through with a purchase of anything without more details being on a tight budget).  He basically told me to wait as it will be on TV soon and to go from there.  Don't you think that if what he has is fake that he would have tried selling me something and gladly taken my money?  But if it is real he would not want to give the concept away to someone unknown to him for a small amount.  I think at some point if it's real he will be teaching others on this.
    So I don't know but I wouldn't discount him yet.  And he has good reason to be 'toting a gun' if you read up a little.
