SELF RUNNING MOTOR WITH JOULE THIEF!
Started by pree5, June 05, 2011, 05:16:59 AM
pree5
gyulasun
Hello Pree5,
Thanks for uploading again!
Any time you manage to build and make it run as you think it should, please come here and share.
Lakes
Very nice animation, what program(s) do you use to make these?
Bruce_TPU
Quote from: TinselKoala on June 06, 2011, 07:38:47 PM
http://www.youtube.com/watch?v=hYQM8WbCq2Y
Very funny Al,
I'm still waiting for reimbursement on the fraud you perpertrated on the FE Community.   Hey, a quick measurement question for you...
If a person perpetrates a fraud, does that make them a fraud?  What measure of a man's character is it who lies and perpetrates fraud and a hoax?  That is the ONLY measurement you need to be concerned with.
@ Everyone,
In case all of you forgot who this TinselKoala is, he is the man who perpetrated the OCAL Magnet Motor Fraud.  Right up there with Mylow, for a character reference.  He is paid a full time salary to critique, and do all he can to make sure that alternative energy is repressed.  Just in case some of you didn't know who he is.
Have a nice day, Al.
Cheers,
Bruce
