dont laugh, i astral traveled and saw the first mass recognised overunity device
Started by gigastorm123, June 06, 2011, 07:22:36 PM
pese
Quote from: Shokac on June 12, 2011, 05:12:30 PM
I tok about this:
this design can make some problems.
the 2 inside,the tube, wire must be insulated!
2.
The "open ends" must have in the uninsulated are (cut) at minimum 1cm Distance !! otherwise this is an "spark gap"
Help:
You can produce easy ozone in the area of an Hg-Vapor-lamp.
Hi force UV-rays will make from O2 an O3.
Pesé
electricme
First of all, a big Thankyou to Gigastorm123 for this new thread.
And welcome to all the others as well.
Giga, You mentioned a number of things which are relevant to several threads on Overunity, the Stubblefield Coil and the Joule Thief to mention just two of them.
The way you have described in your dream I thought you must have popped around to my place, as my Kap has all the colours on and inside it. ;) Don't worry, I have read a pdf which Pirate was so kind to send me which explains a lot.
I see you have mentioned steel wires used in the copper tubing, BTW, this is amazing stuff.
On the Stubblefield Coil, it is made using a Iron and a Copper wire, wound in a Bifilar fashion (2 in parallel) on a steel insulated bolt, basically that's it. I look at the images here and blow me down, it's different but so similar.
On the Joule Thief, it is wound in a similar fashion, as I mentioned above.
Currently I am building a Kapanadze, made almost everything I need, but once again I see very similar comparisons with all as I mentioned above.
This is a very, very interresting topic, please keep up with the excellent posting, I will be looking around in here from time to time to see how things progress.
jim
