Romero's experiments and OU principles
Started by plengo, June 10, 2011, 08:26:08 PM
neptune
@Romerouk . The kromrey machine I refer to . You showed a diagram on page 13 , reply192 , in the thread "re muller dynamo " . I am asking about the ferrite bit .
romerouk
Quote from: neptune on June 16, 2011, 10:40:38 AM
I bought the I ferrite block 10cm long/2.5cm square.(quite expensive, about £22 each- I bought 16)
I used iron dust cores(factory made) for the parts facing the magnets and glued them with the long ferrite that had the coils on it .
I hope u understand, 2 iron dust cores and this ferrite core made the C shape you are talking about.
Romero
woopy
Hi Romero
just a quick question
Is it possible that on the rotor, you use a pair of magnets  in opposition to get a "kind of super pole"  with the same pole outside ? yes or no ?
If yes it could explain why the magnet get something out of the 12 mm thick rotor on the pix we have seen on the other thread (and i remember you spoke of adding magnet on top of each other but you did not say how.
If yes in this case there is no more a Muller divice and it works completely differently.
Thank's and good luck for your next project for me i go on testing and learning and it is a lot of fun
Laurent
romerouk
Quote from: woopy on June 16, 2011, 11:01:36 AM
Hi Romero
Laurent
that was a mistake I made, realised after a while.I changed rotors and everything so many times and I forgot. The rotor was 12mm and because the 10mm magnet was too small I added a 5mm magnet, so total magnet lenght was 15mm
neptune
@Romerouk . Many thanks for answering some of my questions .And woopy`s question . Referring to Woop`s question , can you confirm that when you added the 5mm magnets on the rotor , you added them in attraction and not in repel mode . Thanks .
