Safe One Wire energy transfer by Serbian inventor Milutin Miletic
Started by hartiberlin, June 16, 2011, 11:51:28 AM
hartiberlin
Quote from: FatBird on June 19, 2011, 10:08:57 AM
SIMPLE SIMPLE ANTENNA THEORY?
1.  It looks like there are 3 Enamel Coated Copper Wires (Magnet Wire) mounted on the Wood Board, TOUCHING EACH OTHER.
2.  The 2 wires FROM THE 230V WALL MAINS connect to the 2 OUTSIDE wires on the Wood Board.
3.  There is NO CURRENT drawn from the 230 V Mains, because the 3 wires are insulated wires.
4.  The Middle Wire is the OUTPUT WIRE that powers the bulb and drill motor in the video.
SPECULATION:
1.  The Center Output Wire is Capacitively Coupled and Inductively Coupled to the Outside 2 Mains Wires on the board.
2.  The Center Output Wire acts as an ANTENNA, so to speak.
FURTHER RESEARCH:
1.  If the all Copper Wires don't work, maybe the Center Wire has to be Iron?
2.  Maybe the Center Wire has to be Copper and the Outside Wires Iron?
3.  Maybe 1, 2, or all 3 Wires have to be Iron or Aluminum?
4.  Etc.
No, I think
he shows there only 3 of his units in parallel !
See, he has 3 plugs at the end and 3 steel wires going parallel and also touching each other.
Each steel wire is for one plug at the other end.
He probably wanted to show with it, that the wires can come in contact with each other
and it does not matter and is still safe, when you use 3 phase wire systems...
in the 3rd device he shows, there you can see, how big the transformers are between the steel wire.
Have a look at these 2 devices circled in red color probaly wrapped into some yellow painted paper or plastic foil or something like this....
stprue
Quote from: hartiberlin on June 20, 2011, 06:02:54 PM
No, I think
You are right on with this comment.
FatBird
I found a different Video.  Can someone please Translate this Video to English.
Maybe we can get some more ideas from it.
http://www.youtube.com/watch?v=m_fgmu4wsSI
Thank you.
alan
I think he uses a coil or coils and accesses the 220V as a physical wave, lag the 220V and join it with the 220V input to create 0V, but it's not 0 force or 0 energy?
just a brainfart
futuristic
Quote from: FatBird on June 20, 2011, 09:38:48 PM
Thank you.
Was hoping that someone else would do it but I guess not... :D
So here it is:
0:23
Reporter:
At the first sight it seems as a regular copper wire, you turn on electricity and on the other end light bulb glows, but as Milutin Miletic says this wire can be touched with no worries with bare hands even when connected to the electricity. Isolator is not needed and current does not kill anymore.
MM:
I have the product: wire that transfers energy without charge and without emitting electrons. So you don't have 220 volts, but 0 volts.
Reporter:
For more than 20 years MM in his apartment used his invention to save on electricity. Wire does not need insulation and it can be used in many ways.
MM:
Wire can be used for heating or just for energy transfer.
When used for hearing it can have temperature from 20 degrees Celsius to 1000 degrees Celsius.
It depends on the material you use to maintain this high temperature.
Reporter:
For his invention "electricity conductor" MM has special formula, he makes the wire by himself and he says the manufacturing process is not complicated.
He does not have a special research laboratory.
MM (1:32)
**** Sorry but I don't understand what is he saying, perhaps we have some native speakers from Serbia on forum?... ***
Something about thousand chemical materials...
Reporter:
MM says that he invented his special wire 20 years ago. He claims that if this wire would be used in the households there would be no more accidents and fires because of short circuits.
